1 Reply Latest reply on Jan 7, 2014 11:28 AM by Josh_Corey
    How to place two text fields on the same line in adobe
    urgentcare
      I am trying to create a form on adobe and I would like to have two unique text fields on the same line. Is this posible?
        • 1. Re: How to place two text fields on the same line in adobe
          Josh_Corey Adobe Employee
          If you are using FormsCentral it is, the fields can be placed "side by side" in a row.  There is a "+" sign on the right side of the field that brings up a toolbar to add a field adjacent.  You can also right click on a field and select "Insert beside", or you can "drag and drop" fields next to one another or to a new row.
          Josh
          PS - One note, if you are using the "desktop" application of FormsCentral that comes with Acroat Pro XI make sure the application is up to date by either using the "Help" - "Check for updates" menu item or by signing into the application so that you have the latest features including the side by side layout.
