HI, I want to link multiple framemaker books to robohelp and use each book as a child project in a master project. However, there are multiple hyperlinks between the framemaker books. I have created individual RH projects, and linked a single book to each project. I generated them all into a master project (as usual), but the hyperlinks between the projects (that worked fine between the PDFs generated from the original Framemaker books) are broken in the output. I check the html of the hyperlinks in RH, and while the text is recognized as a hyperlink, the href tag is missing.
Note: All links with target and destination in the same book / project work fine.
I could create a single book containing all these books, and then link this book to FM, and this would probably avoid the issue, but it wouldn't be a good solution as I would then have workflow / source control issues. Also, I would obviously prefer not to have to manually repair the links in RH, due to time contstraints.
Any suggestions?
How long a path length are you looking at for the linked FM documents? It turns out that RH is very sensitive to the length of the paths that make up the cross-references in FM when turning them into hyperlinks in RH.
