7 Replies Latest reply on Nov 15, 2006 6:45 AM by Newsgroup_User
    css floats
    m0piqsutjjqv4du
      I would like to create a "floating table" (for lack of a better description)
      Where as There would be a block element say <p id="thisblock">This block would have some text, images, all formatted and wrapped in a border - thanks to #thisblock {...} in css</p>
      now in that box, i would like to put a list that would split down 2 columns, left one will be aligned right, right aligned left ie:
      ________XXXXXXXXXXXXXXXX_____XXXXXXXXXXXXXXXXXXXXX
      __ XXXXXXXXXXXXXXXXXXXXXX____XXXXXXXXXXXXXXXXXXXXXXXX
      _________ XXXXXXXXXXXXXXX____XXXXXXXXXXXXXXXXXXXXXXX
      then some more text down here
      well you get the idea. I tried using floats, but of course the "then some more text" ends up buried under the list. I tried clear: both, but that didn't help. im new to css and any help would be appreciated!
        • 1. Re: css floats
          Level 7
          Why not use a table within the floating element?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "m0piqsutjjqv4du" <webforumsuser@macromedia.com> wrote in message
          news:ejakns$338$1@forums.macromedia.com...
          >description)
          > would
          > columns,
          > border
          > more
          > help.
          > Thanks
          • 2. Re: css floats
            m0piqsutjjqv4du Level 1
            ahh yes...
            Simplicity!
            I guess in my attempt to steer away from tables in design, it's also important to consider that if you need a table in content - use a table!
            Ha Ha - Thanks Murray!
            • 3. Re: css floats
              Level 7
              You're welcome!
              news:ejch27$b3p$1@forums.macromedia.com...
              > ahh yes...
              > Simplicity!
              • 4. Re: css floats
                is there an efficient way to format this table, rather than setting align and width values to each individual table cell? it just seems like an awful lot of redundant code...
                • 5. Re: css floats
                  Level 7
                  td {
                  text-align:left;
                  Or whatever. :)
                  Widths you only need to set on the first row and the rest will follow.
                  news:ejcm2j$gsq$1@forums.macromedia.com...
                  • 6. Re: css floats
                    yes, but this table would need 1/2 the cells (left column) align:right, and the right aligned left. I think i'm gonna use two different tables, it should produce the desired effect....
                    • 7. Re: css floats
                      Level 7
                      Either way. You'd have to pick a default alignment, then use a class in
                      order to use CSS for that. Or depending on your page structure, maybe some
                      special selectors. If you have different tables, each can have an ID.
                      #leftTable td {
                      text-align:left;
                      #rightTable td {
                      text-align:right;
                      That kind of thing.
                      It should end up with a lot less code on the page than having
                      align="something" on every cell. ;)
                      news:eje2tv$95s$1@forums.macromedia.com...
