1 Reply Latest reply on Dec 3, 2007 3:21 AM by Newsgroup_User
    Install - InvocationTargetException
    Phobos0
      I attempted to install Flex Builder Linux Public Alpha by following (precisely) the instructions presented at http://labs.adobe.com/technologies/flex/flexbuilder_linux/, however I received the following error message:
      Preparing to install...
      Extracting the installation resources from the installer archive...
      Configuring the installer for this system's environment...
      Launching installer...
      Invocation of this Java Application has caused an InvocationTargetException. Thi
      s application will now exit. (LAX)
      Stack Trace:
      java.awt.HeadlessException
      at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:1 21)
      at java.awt.Window.<init>(Window.java:274)
      at java.awt.Frame.<init>(Frame.java:401)
      at java.awt.Frame.<init>(Frame.java:366)
      at javax.swing.JFrame.<init>(JFrame.java:154)
      at com.zerog.ia.installer.LifeCycleManager.g(DashoA8113)
      at com.zerog.ia.installer.LifeCycleManager.h(DashoA8113)
      at com.zerog.ia.installer.LifeCycleManager.a(DashoA8113)
      at com.zerog.ia.installer.Main.main(DashoA8113)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:324)
      at com.zerog.lax.LAX.launch(DashoA8113)
      at com.zerog.lax.LAX.main(DashoA8113)
      This Application has Unexpectedly Quit: Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
      Suggestions are welcomed,
      ((¯`·.¸¸.·´¯`·-» ρђσßσЅф «-·´¯`·.¸¸.·´¯))
        • 1. Re: Install - InvocationTargetException
          Level 7
          > Thi
          > Stack Trace:
          > at
          > 21)
          > at
          > java:39)
          > at
          > sorImpl.java:25)
          > ((¯`·.¸¸.·´¯`·-» ???ß??? «-·´¯`·.¸¸.·´¯))
          What version of Java are you using. I am not sure but you may also want
          to look at this link if it helps you ? (probably might let you know
          where you are going wrong?)
          http://codetouch.blogspot.com/2007/10/installing-flex-builder-linux-alpha.html
          Arun
