This content has been marked as final.
Show 4 replies
1. Re: Safe to delete files after Master Suite CS6 installation on Windows 7 , 64 bit system?
BobLevine Jan 9, 2014 5:28 AM (in response to reindeer4)Those are downloaded installer files. The folder is the extracted version of
the files which the system actually used to install them. You should back up
one or the other but they can all be removed safely and are not required to
run the software.
2. Re: Safe to delete files after Master Suite CS6 installation on Windows 7 , 64 bit system?
reindeer4 Jan 9, 2014 5:54 AM (in response to BobLevine)Thank you Bob.
Just to clarify - in terms of backing up one set of these, would that just be so I had it on disk and didn't need to re-download from Adobe if the installation got corrupted somehow? Or do I need a backup for some other reason?
3. Re: Safe to delete files after Master Suite CS6 installation on Windows 7 , 64 bit system?
BobLevine Jan 9, 2014 6:25 AM (in response to reindeer4)Correct. Or if you buy a new machine and need to install.
4. Re: Safe to delete files after Master Suite CS6 installation on Windows 7 , 64 bit system?
reindeer4 Jan 9, 2014 6:35 AM (in response to BobLevine)Ok. Thanks for your help.
