0 Replies Latest reply on Jan 9, 2014 5:18 AM by Raphael.tebarts
    FindChangeByList.jsx changing multyple files
    Raphael.tebarts
      Hello everyone,
      I found this helpfull script wich change all open documents for CS5.5.
      Is it possible to use it for CS4? At this moment it doesnt work!
      Here`s the links:
      http://forums.adobe.com/thread/947527
      Here`s the script:
      / Copyright ZITRONE Romano Studer
      // Melbourne, Australia 2012
      // www.zitrone.com.au
      // Changes to the code in order to process multyple files
      //target any InDesign
      #target "InDesign"
      //FindChangeByList.jsx
      //An InDesign CS5.5 JavaScript
      @@@BUILDINFO@@@ "FindChangeByList.jsx" 3.0.0 15 December 2009
      //Loads a series of tab-delimited strings from a text file, then performs a series
      //of find/change operations based on the strings read from the file.
      //The data file is tab-delimited, with carriage returns separating records.
      //The format of each record in the file is:
      //findType<tab>findProperties<tab>changeProperties<tab>findChangeOptio ns<tab>description
      //Where:
      //<tab> is a tab character
      //findType is "text", "grep", or "glyph" (this sets the type of find/change operation to use).
      //findProperties is a properties record (as text) of the find preferences.
      //changeProperties is a properties record (as text) of the change preferences.
      //findChangeOptions is a properties record (as text) of the find/change options.
      //description is a description of the find/change operation
      //Very simple example:
      //text          {findWhat:"--"}          {changeTo:"^_"}          {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}          Find all double dashes and replace with an em dash.
      //More complex example:
      //text          {findWhat:"^9^9.^9^9"}          {appliedCharacterStyle:"price"}          {include footnotes:true, include master pages:true, include hidden layers:true, whole word:false}          Find $10.00 to $99.99 and apply the character style "price".
      //All InDesign search metacharacters are allowed in the "findWhat" and "changeTo" properties for findTextPreferences and changeTextPreferences.
      //If you enter backslashes in the findWhat property of the findGrepPreferences object, they must be "escaped"
      //as shown in the example below:
      //{findWhat:"\\s+"}
      //For more on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
      //or visit the InDesign Scripting User to User forum at http://www.adobeforums.com
      main();
      function main(){
                var myObject;
                //Make certain that user interaction (display of dialogs, etc.) is turned on.
                app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
                if(app.documents.length > 0){
                          if(app.selection.length > 0){
                                    switch(app.selection[0].constructor.name){
                                              case "InsertionPoint":
                                              case "Character":
                                              case "Word":
                                              case "TextStyleRange":
                                              case "Line":
                                              case "Paragraph":
                                              case "TextColumn":
                                              case "Text":
                                              case "Cell":
                                              case "Column":
                                              case "Row":
                                              case "Table":
                                                        myDisplayDialog();
                                                        break;
                                              default:
                                                        //Something was selected, but it wasn't a text object, so search the document.
                                                        myFindChangeByList(app.documents.item(0));
                          else{
                  //Nothing was selected, so simply search the document.
                  var myNumberOfDocuments = app.documents.length;
                  //The FindChangeList.txt file used to be aquirred inside the myFindChangeByList function. Hence we would ask for it many times.
                  //Here we ask only one time. We use the same FindChangeList.txt file for the operation on all InDesign files.
                  var myFindChangeFile = myFindFile("/FindChangeSupport/FindChangeList.txt")
                  for(i=0;i<myNumberOfDocuments;i++){
                      myFindChangeByList(app.documents.item(i), myFindChangeFile);
                else{
                          alert("No documents are open. Please open a document and try again.");
      function myDisplayDialog(){
                var myObject;
                var myDialog = app.dialogs.add({name:"FindChangeByList"});
                with(myDialog.dialogColumns.add()){
                          with(dialogRows.add()){
                                    with(dialogColumns.add()){
                                              staticTexts.add({staticLabel:"Search Range:"});
                                    var myRangeButtons = radiobuttonGroups.add();
                                    with(myRangeButtons){
                                              radiobuttonControls.add({staticLabel:"Document", checkedState:true});
                                              radiobuttonControls.add({staticLabel:"Selected Story"});
                                              if(app.selection[0].contents != ""){
                                                        radiobuttonControls.add({staticLabel:"Select ion", checkedState:true});
                var myResult = myDialog.show();
                if(myResult == true){
                          switch(myRangeButtons.selectedButton){
                                    case 0:
                                              myObject = app.documents.item(0);
                                              break;
                                    case 1:
                                              myObject = app.selection[0].parentStory;
                                              break;
                                    case 2:
                                              myObject = app.selection[0];
                                              break;
                          myDialog.destroy();
                          myFindChangeByList(myObject);
                else{
                          myDialog.destroy();
      function myFindChangeByList(myObject, myFindChangeFile){
                var myScriptFileName, myFindChangeFile, myFindChangeFileName, myScriptFile, myResult;
                var myFindChangeArray, myFindPreferences, myChangePreferences, myFindLimit, myStory;
                var myStartCharacter, myEndCharacter;
                //var myFindChangeFile = myFindFile("/FindChangeSupport/FindChangeList.txt")
                if(myFindChangeFile != null){
                          myFindChangeFile = File(myFindChangeFile);
                          var myResult = myFindChangeFile.open("r", undefined, undefined);
                                    //Loop through the find/change operations.
                                    do{
                                              myLine = myFindChangeFile.readln();
                                              //Ignore comment lines and blank lines.
                                              if((myLine.substring(0,4)=="text")||(myLine.subst ring(0,4)=="grep")||(myLine.substring(0,5)=="glyph")){
                                                        myFindChangeArray = myLine.split("\t");
                                                        //The first field in the line is the findType string.
                                                        myFindType = myFindChangeArray[0];
                                                        //The second field in the line is the FindPreferences string.
                                                        myFindPreferences = myFindChangeArray[1];
                                                        //The second field in the line is the ChangePreferences string.
                                                        myChangePreferences = myFindChangeArray[2];
                                                        //The fourth field is the range--used only by text find/change.
                                                        myFindChangeOptions = myFindChangeArray[3];
                                                        switch(myFindType){
        case "text":
        myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
        break;
        case "grep":
        myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
        break;
        case "glyph":
        myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
        break;
                                    } while(myFindChangeFile.eof == false);
                                    myFindChangeFile.close();
      function myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
                //Reset the find/change preferences before each search.
                app.changeTextPreferences = NothingEnum.nothing;
                app.findTextPreferences = NothingEnum.nothing;
                var myString = "app.findTextPreferences.properties = "+ myFindPreferences + ";";
                myString += "app.changeTextPreferences.properties = " + myChangePreferences + ";";
                myString += "app.findChangeTextOptions.properties = " + myFindChangeOptions + ";";
                app.doScript(myString, ScriptLanguage.javascript);
                myFoundItems = myObject.changeText();
                //Reset the find/change preferences after each search.
      function myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
                //Reset the find/change grep preferences before each search.
                app.changeGrepPreferences = NothingEnum.nothing;
                app.findGrepPreferences = NothingEnum.nothing;
                var myString = "app.findGrepPreferences.properties = "+ myFindPreferences + ";";
                myString += "app.changeGrepPreferences.properties = " + myChangePreferences + ";";
                myString += "app.findChangeGrepOptions.properties = " + myFindChangeOptions + ";";
                var myFoundItems = myObject.changeGrep();
                //Reset the find/change grep preferences after each search.
      function myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
                //Reset the find/change glyph preferences before each search.
                app.changeGlyphPreferences = NothingEnum.nothing;
                app.findGlyphPreferences = NothingEnum.nothing;
                var myString = "app.findGlyphPreferences.properties = "+ myFindPreferences + ";";
                myString += "app.changeGlyphPreferences.properties = " + myChangePreferences + ";";
                myString += "app.findChangeGlyphOptions.properties = " + myFindChangeOptions + ";";
                var myFoundItems = myObject.changeGlyph();
                //Reset the find/change glyph preferences after each search.
      function myFindFile(myFilePath){
                var myScriptFile = myGetScriptPath();
                var myScriptFile = File(myScriptFile);
                var myScriptFolder = myScriptFile.path;
                myFilePath = myScriptFolder + myFilePath;
                if(File(myFilePath).exists == false){
                          //Display a dialog.
                          myFilePath = File.openDialog("Choose the file containing your find/change list");
                return myFilePath;
      function myGetScriptPath(){
                try{
                          myFile = app.activeScript;
                catch(myError){
                          myFile = myError.fileName;
                return myFile;
      Thanks!
      Raphael
