• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Issue with autosuggest on a numeric field
New Here ,
Nov 30, 2007 Nov 30, 2007
I have a form with a CFINPUT that has autosuggest to a cfc. The cfc runs a query against a varchar field that has only numeric values. When the match is made and the lis is returned I get an error (Bind failed for autosuggest CUSTOMER, bind value is not a 1D array of strings). This only happens with fields that are all numeric, if the field has any letters or symbols I do not have this issue.
The data returned is coming back as numeric in scientific notation (CFC invocation response: [5.159000038E9]) The data is matching on the phone number and that is what is being returned.
It there a way to correct this issue? Code sample is below.
<cfinput type="text" name="CUSTOMER" size="10" maxlength="10" value="#CUSTOMER#" autosuggest="cfc:customerInfo.getCustomerSuggest({DSN}, {cfautosuggestvalue})">
here is the function from the CFC:
<cffunction name="getCustomerSuggest" access="remote" returntype="array" output="false">
<cfargument name="argDB" type="string" required="yes">
<cfargument name="argCUSTOMER" type="string" required="yes">
<cfset var myarray = ArrayNew(1)>
<cfquery name="cstInfo" datasource="#argDB#" maxrows="25">
SELECT customer
FROM custFile
WHERE customer LIKE <cfqueryparam value="#argCUSTOMER#%" cfsqltype="CF_SQL_VARCHAR">
</cfquery>
<cfloop query="cstInfo">
<cfset arrayAppend(myarray, '#customer# ')>
</cfloop>
<cfreturn myarray>
</cffunction>
TOPICS
Advanced techniques
Views
646
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
Dec 01, 2007 Dec 01, 2007
I don't understand the actual results desired. But I would make my cffunction returntype a string and get rid of the cfloop that creates your array. One of my autosuggest cfcs is;
<cffunction name="getJobsearch" access="remote" returnType="string" output="false">
<cfargument name="term" type="string" required="false">
<cfset var Jqry = "">
<cfquery name="Jqry" datasource="taxsearchdb">
SELECT J.CompanyName + ' ' + J.CompanyCity + ' ' + C.State + ' ^' + cast(J.JobOrderNumber as varchar) as Jname
FROM jorder J, Companies C
WHERE J.CompanyNumber = C.CompanyRecordNumber and J.CompanyName LIKE <cfqueryparam cfsqltype="cf_sql_var" value="#trim(arguments.term)#%">
</cfquery>
<cfreturn ValueList(Jqry.Jname)>
</cffunction>
Votes
Translate
Translate
Report
Report
Explorer ,
Just a note;
I return a list of fields that has company name and city and state and job number concatenated. The caret ^ is used later to find the job number in the field Jname.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thank you, changing it to a string worked great.
Votes
Translate
Translate
Report
Report
Resources
Documentation
