1. Re: Captivate 7 Software Simulation no longer records.
Flo_Time Jan 9, 2014 12:02 PM (in response to Flo_Time)Problem solved.
For some reason Captivate will no longer capture mouse clicks or movements on my secondary monitor. I've never had this issue before but... To solve the issue i simply moved my recording window to my primary monitor. Everything is good now.
2. Re: Captivate 7 Software Simulation no longer records.
Sankaram Jan 10, 2014 1:34 AM (in response to Flo_Time)Hi Flo_Time,
May I know Captivate 7 version number? version number can be found via Help: About Adobe Captivate. Mouse clicks on secondary monitor should work in 7.0.1.237.
Sankaram.
3. Re: Captivate 7 Software Simulation no longer records.
Eddiebo924 Mar 24, 2014 3:18 PM (in response to Flo_Time) -
4. Re: Captivate 7 Software Simulation no longer records.
JazzRunner Mar 24, 2014 4:42 PM (in response to Flo_Time)The problem I had sounds similar to yours. When I attempted to record a software simulation on my secondary monitor, Captivate would capture keyboard-based actions and manual requests for screen shots (Prt Scr), but it would not capture mouse-click actions. The solution I found for this problem was to move the recording window, the red rectangle, to my primary monitor. Once there, all actions, including mouse-click actions, were recorded. I even found that I could switch which monitor was my primary monitor and Captivate would record normally as long as the recording window was on my system's primary monitor.
Hope this helps.
5. Re: Captivate 7 Software Simulation no longer records.
rconnor May 12, 2014 1:10 AM (in response to Flo_Time)I'm having the same issue also - with the same version - Capitave 7.0.1.237 - OS - Windows 7 Enterprise SP1 32bit
Help!
6. Re: Captivate 7 Software Simulation no longer records.
Eddiebo924 May 12, 2014 7:49 AM (in response to rconnor)It doesn't work when you're recording on you primary display? As long as I move what I want to record to the primary display, it works every time with not issues at all.
7. Re: Captivate 7 Software Simulation no longer records.
rconnor May 14, 2014 7:33 AM (in response to Flo_Time)Hi! Yes it does however that's not the point! I often have to switch resolutions to create a recording that is a standard size. I do this on my secondary rather than primary monitor.
8. Re: Captivate 7 Software Simulation no longer records.
Marltutski Nov 12, 2014 10:38 AM (in response to Flo_Time)I thought I was going mad. I am a new Captivate user, using Software Simulations on Captivate 8. I moved the screen capture to my primary monitor and it all started working. Thank you.
