2 Replies Latest reply on Jan 10, 2014 4:46 AM by Cari Jansen
    Need urgent help! Thanks!
    Jesse Jamie
      Created an interactive pdf file with sound and buttons. After exporting as an interactive pdf file the buttons do not show.
        • 1. Re: Need urgent help! Thanks!
          Salah Fadlabi Level 5
          Viewed on acrobat pdf or others pdf viewers?
          • 2. Re: Need urgent help! Thanks!
            Cari Jansen Adobe Community Professional
            There's a couple of things you can check.
            In your InDesign document, when you go to a page containing buttons:
            • From the View menu > Overprint Preview.
            Can you see the buttons? If they have disappeared, than they might be set to be non-printing objects.
            • Select the button
            • Window > Output > Attributes
            • In the Attributes panel, deselect non-printing.
            The buttons can also be placed on a non-printing layer:
            • Select the layer
            • From the Layer panel menu select Layer Options for [layername]
            • Ensure the Print Layer option is selected.
            Which PDF export settings are using?
            If you are choosing File > Export and selecting format Adobe PDF (Print), and Interactive Elements are set to Do Not Include, all interactive objects will vanish from the PDF output.
            Instead choose File > Export, and select format Adobe PDF (Interactive)
            In the Export to Interactive PDF dialog ensure Forms & Media is set to Include All.
