4 Replies Latest reply on Jan 10, 2014 2:59 PM by A.T. Romano
    Red line above the time line
    freedog69
      How do I get it so after initially importing my video the line above the time line will be green instead of red.  It stays red until after I render the whole clip.  I am importing my video clips from my camcorder.  How do you determine the correct project settings if that is the issue?
        • 1. Re: Red line above the time line
          A.T. Romano Level 7
          freedog69
          Not possible as worded. If you have the correct project preset, there will be no colored line over this Timeline content.
          If you do not have the correct project preset, there will be a red line over this Timeline content.
          What version of Premiere Elements are you using and on what computer operating system is it running?
          If you are talking "red" line, then you must be working with a version of Premiere Elements earlier than 11. Assuming that....
          If your project preset matches the properties of your source media, then, when you bring one of those files to the Timeline, you will get no colored line over the Timeline. But, after that, after you edit that content, a red line will appear. That is when you render the Timeline content to turn the line green.Thereafter, that original content will never revert to the no colored line status as you work through editing that project. It will just go through the red green color indicator system.
          No colored line and green = the program telling you that you now have the best possible preview of the Timeline content when viewing it in the Edit Mode monitor playback. Red line = the program telling you that you do not have the best possible preview of the Timeline content and, if you want that, then you can press the Enter key of the computer main keyboard to make that happen.
          What are the properites of your source media...
          video and audio compression
          frame size
          frame size
          interlaced or progressive
          file extension
          pixel aspect ratio
          What brand/model/settings camera provided you will the source media for the Premiere Elements 10 project.
          Form that information, I will suggest to you the appropriate project preset. Depending on what you have, Premiere Elements may not have a project preset to match your video properties. Some programs have a feature which claims to help you select the right project preset.
          The information requested above will help me to help you to define you situation in term of your source media and the most appropriate project settings.
          Looking forward to your follow up.
          Thanks.
          ATR
          • 2. Re: Red line above the time line
            freedog69 Level 1
            Thanks for the speedy reply.  My end result is to be able to upload  the
            files to YouTube at 720 HD format this way the files are about 500mb a  piece.
            I have been choosing  HDV720P leaving all defaults  My  answers to your
            questions below in Red
            Thanks again
            Chris
            In a message dated 1/9/2014 5:00:15 P.M. Eastern Standard Time,
            forums_noreply@adobe.com writes:
            created by A.T. Romano (http://forums.adobe.com/people/A.T.+Romano)  in
            Premiere Elements - View the full  discussion
            (http://forums.adobe.com/message/5998225#5998225)
            • 3. Re: Red line above the time line
              freedog69 Level 1
              freedog69
              operating system is it running? APE 8  Windows XP 3GB  of ram Pentium Dual core
              Proc 2.41 Ghz
              happen.
              What are the properites of your source media... Canon HF  10 camera and
              Panasonic HV-720
              frame size
              frame size
              file extension
              pixel aspect ratio
              General Panasonic  HV-720
              Complete  name                     : K:\Busters_Tap\New
              Matches-CamB\f0069412.m2ts
              Format                            :  BDAV
              Format/Info                       : Blu-ray Video
              File  size                         : 2.00  GiB
              Duration                          : 58mn 59s
              Overall bit  rate                  : 4 854 Kbps
              Maximum Overall bit  rate         : 18.0 Mbps
              Video
              Menu  ID                           : 1  (0x1)
              Format                            :  AVC
              Format/Info                       : Advanced Video Codec
              Format  profile                    : High@L4.0 (mailto:High@L4.0)
              Format  settings, CABAC           :  Yes
              Format settings, ReFrames        : 2  frames
              Format settings,  GOP             :  M=1, N=30
              Codec  ID                          :  27
              Duration                          : 58mn 59s
              Bit rate  mode                     : Variable
              Bit  rate                          : 4 267 Kbps
              Maximum bit  rate                  : 16.8  Mbps
              Width                             : 1 920  pixels
              Height                            : 1 080 pixels
              Display aspect  ratio             :  16:9
              Frame  rate                        : 29.970 fps
              Color  space                       : YUV
              Chroma  subsampling                : 4:2:0
              Bit  depth                         : 8 bits
              Scan  type                         : Interlaced
              Scan  order                        : Top Field  First
              Bits/(Pixel*Frame)                : 0.069
              Stream  size                       : 1.76 GiB (88%)
              Audio
              Menu  ID                           : 1  (0x1)
              Format                            :  AC-3
              Format/Info                       : Audio Coding 3
              Mode  extension                    : CM (complete main)
              Codec  ID                          :  129
              Duration                          : 58mn 59s
              Bit rate  mode                     : Constant
              Bit  rate                          : 384  Kbps
              Channel(s)                        : 2 channels
              Channel  positions                 : Front: L R
              Sampling  rate                     : 48.0 KHz
              Bit  depth                         : 16 bits
              Compression  mode                  : Lossy
              Delay relative to  video          : -558ms
              Stream  size                       : 162 MiB (8%)
              Text
              Menu  ID                           : 1  (0x1)
              Format                            : PGS
              Codec  ID                          :  144
              Duration                          : 58mn 58s
              Delay relative to  video          : 34ms
              General- Canon HF  10
              Complete  name                     : K:\Busters_Tap\New Matches
              CAM-A\00001.MTS
              Format                            :  BDAV
              File  size                         : 1.90  GiB
              Duration                          : 49mn 5s
              Overall bit  rate                  : 5 551 Kbps
              Maximum Overall bit  rate         : 13.7 Mbps
              Video
              Menu  ID                           : 1  (0x1)
              Format                            :  AVC
              Codec  ID                          :  27
              Duration                          : 49mn 5s
              Bit  rate                          : 5 066 Kbps
              Maximum bit  rate                  : 12.0  Mbps
              Width                             : 1 440  pixels
              Color  space                       : YUV
              Bit  depth                         : 8 bits
              Bits/(Pixel*Frame)                : 0.109
              Stream  size                       : 1.74 GiB (91%)
              Audio
              Menu  ID                           : 1  (0x1)
              Format                            :  AC-3
              Codec  ID                          :  129
              Duration                          : 49mn 5s
              Bit  rate                          : 256  Kbps
              Bit  depth                         : 16 bits
              Delay relative to  video          : -66ms
              Stream  size                       : 89.9 MiB (5%)
              Premiere Elements 10 project.  Canon HF 10 and  Panasonic HV-720
              • 4. Re: Red line above the time line
                A.T. Romano Level 7
                freedog69
                Thank you for the helpful details. Here are my suggestions for your consideration to determine if they work for you.
                Premiere Elements (any version) allows only one project preset. And, that project preset should match the properties of the source media, especially if you do not want to see a red line over its content when it is first dragged to the Timeline. When you have more than one format, as you do, the priorities need to be set. But you are not going to escape the red line over the content of video with the different format than the first.
                What do you want to do? Use each in a movie of its own? Or, use both sources in one movie?
                1. If the Panasonic HV-720 (1920 x 1080 @ 29.97 interlaced frames per second is to be used in a movie of its own
                a. Project Preset = NTSC/AVCHD/Full HD1080i30
                b. Share/Online/YouTube with preset = High Definition Video for YouTube - 1920 x 1080.
                Note: When you bring this video into the Timeline with this project preset, you should not get a colored line over its Timeline content (until after you edit it).
                2. If the Canon (1440 x 1080 HD anamorphic 16:9 @ 29.97 interlaced frames per second is to be used in a movie of its own
                a. Project Preset = NTSC/AVCHD/HD1080i30
                Note:
                There is a YouTube preset for 1440 x 1080, but I prefer to use the 1920 x 1080 one to avoid the use of the 16:9 flag which stretches the 1440 x 1080 to 1920 x 1080 for display after encoding. You could try both if you like.
                When you bring this video into the Timeline with the project preset cited, you should not get a colored line over its Timeline content (until after you edit it).
                3. Now if you are using both in the same movie, I would select
                b. Import the Panasonic footage - no colored line (until after edit).
                c. Import the Canon footage - red line over content, render
                d. Share/Online/YouTube with preset = High Definition Video for YouTube - 1920 x 1080.
                Please let us know the outcome. If you need clarification on any of the above, please do not hesitate to ask.
                Thank you.
                ATR
