6 Replies Latest reply on Jan 12, 2014 7:06 AM by myDavey
    InDi CS6 not saving prefs
    myDavey Level 1
      Hi
      All of a sudden my InDesign is not saving my prefs
      I set/change prefs with all documents closed but still when reopen Indesign, all prefs are reset.
      I did have to reset my prefs about a week ago, but I am not sure if thats when it started...
      I use in-tools preference manager script to restore my prefs... but its driving me crazy to have to do it each time InDi opens!!
      If anyone can help me with this I would really appreciate it
      Davey
        • 1. Re: InDi CS6 not saving prefs
          Cari Jansen Adobe Community Professional
          Cari
          • 2. Re: InDi CS6 not saving prefs
            myDavey Level 1
            Hi Cari
            Thanks for your response
            • Prefs and caches were both cleared
            • All those folders have read/write permissions to the system - to others only read (But it doesnt seem to me that it would need to be read/write to all since all the library folders are only to system)
            • Regarding 3rd party plugins, I am not sure how I would do that. I should just drag their folders out of the Applications/Indesgin/Plugins folder?
            Davey
            • 3. Re: InDi CS6 not saving prefs
              Quit InDesign.
              Then:
              • Launch Adobe Extension Manager
              • Select InDesign
              • Deselect extensions that don't list 'Adobe Systems' as Author.
              Or
              • In your Applications or Program s folder find: InDesign folder
              • Create a folder called Plug-ins DIsabled (or something of that nature)
              • From the Plug-Ins folder drag any thrid party plug-ins to Plug-Ins Disabled folder.
              Relaunch InDesign, and see if things work OK now.
              If all of that doesn't work and you're on a Mac:
              • Quit all applications
              • Launch Applications > Utilities > Disk Utitlity
              • Select your Hard Drive on left
              • Click Verify Disk Permissions if there are errors then
              • Repair Disk Permisions
              Reboot your computer, relaunch InDesign and see if that works.
              • 4. Re: InDi CS6 not saving prefs
                myDavey Level 1
                Hi Cari
                Thanks for your extensive detailed help
                However, sad enough, all this did not help!
                I dont know if this would help, but its worth a try:
                I started noticing this issue after A Mac Technical support agent made me do the following:
                • Enable root user
                • delete all caches
                • delete preferences
                • delete LaunchAgents
                • delete LaunchDaemons
                I cant say that I know for sure that one has to do with the other, but just in case.
                However, all of the Mac experts advice didnt help that issue, so I put back all my prefs and caches etc and it is still not working properly
                Again, Thanks!
                And, if anyone can offer any other help I would greatly appreciate it
                Davey
                • 5. Re: InDi CS6 not saving prefs
                  hi Davey,
                  Have you run Utilities > Disk Utility and tried 'Verifying Permissions' ... what comes up? If there are errors, click 'Repare Permissions'.
                  If that doesn't work try the following...
                  Create a new user account on your computer:
                  • Open System Preferences and Click Users & Groups.
                  • Click the lock to make changes (you'll be prompted for your password)
                  • Under Login Options, click the +
                  • and Create a New User Account.
                  • Set New Account to: 'Administrator', and fillin the rest of the fields, click Create User.
                  Now please Log-out of your current user account and log-in with the new account:
                  • Apple menu > Log Out [username]
                  • Launch InDesign and try to change some preferences, then close InDesign.
                  • Relaunch InDesign and see if the preferences are retained.
                  • Now try and create a new document, and change some document specific preferences, and save document, and close InDesign.
                  • Relaunch InDesign.
                  Are the preferences retained?
                  IF they are, then there is something not quite right on your present user-account.
                  If you are 'daring' enough on your current log-in -- and this is a 'at your own risk comment ;-) :
                  • /Users/[username]/Library/Preferences  Rename the 'Adobe' folder in her 'Adobe.old' and rename the 'Adobe InDesign' folder 'Adobe InDesign.old'.
                  • Still in preferences... scroll down to com.adobe.InDesign.plist and rename 'old.com.adobe.InDesign.plist'.
                  If this still doesn't fix things...  and this is also an 'at your own risk' thing to do - I'd suggest you do this with the help of a Mac expert.
                  • Rename the entire Preferences folder  Preferences.old
                  To learn about which preferences are document vs applicaiton based - Mike Rankin wrote a visual guide for InDesign prferences, that outlines which are application and document preferences (it's for CS5.5, but should be ok to work from as well) - see http://indesignsecrets.com/a-visual-guide-to-indesign-preferences.php
                  • 6. Re: InDi CS6 not saving prefs
                    myDavey Level 1
                    Hi Cari
                    Thanks again for your extensive and professional answer! (You seem to be a Mac expert yourself!)
                    After reading your post, before even doing anything, it dawned on me that maybe InDesign is reading prefs from 2 different places.
                    The Mac expert had told me to rename the preferences folder to Preferences Old - not specifying exactly how, so I named it "Preferences_Old".
                    I removed that folder and everything now works!!!
                    It seems that InDeisgn just looks for a Preferences folder, no matter of there is a suffix to it!! (Sounds unprofessional!)
                    Anyway, Thanks again for all your help - it at least led me into the right direction.
                    All the best
                    Davey
                    P.S. Thanks for that link - I was wondering that for a while!
