0 Replies Latest reply on Jan 9, 2014 5:33 PM by olegkon
    Using XMLListCollection with ADG
    olegkon
      I am trying to implement Object Model Explorer (something like Windows Explorer which would allow users to view & modify
      data in ORM kind of system consisting of 1000s of classes, so I need to dig into Classes which are 10s of levels deep
      (Class can contain other Classes or Attributes/primitives).
      In that case Path is not like a package, but true containment.
      Currently I am trying to implement a POC of such system with data in static XML.
      I tried to use Flex3 AdvancedDataGrid (with 1st column as a "Path", i.e. Hierarchical data - Tree kind of view).
      Tried to put data in XML, make XMLListCollection a dataProvider for ADG,
      was able to do it for simple cases, but when I do even simple thing like put a node as a data container:
      <node>
      <attr1>attrA</attr1>
      <attr2>attrB</attr2>
      </node>.
      that data is not showing up in ADG.
      Can you recommend a working code sample of XMLListCollection as dataProvider for ADG?
      (preferable with Hierarchical Data, not Grouping. although for starters regular data is OK too)
      TIA,
      Oleg.
