1 Reply Latest reply on Jan 9, 2014 5:59 PM by BenPleysier
    Center spry menu
    ZSmith16
      Hello, I am trying to center my spry menu however I am having some trouble. I am trying to create a fluid layout so I have a <div> where my content will go and I set its width to 80%. Here is the CSS for the menu. Thanks.
      @charset "UTF-8";
      /* SpryMenuBarHorizontal.css - version 0.6 - Spry Pre-Release 1.6.1 */
      /* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
      LAYOUT INFORMATION: describes box model, positioning, z-order
      /* The outermost container of the Menu Bar, an auto width box with no margin or padding */
      ul.MenuBarHorizontal
                padding: 0;
                list-style-type: none;
                font-size: 90%;
                cursor: default;
                width: 100%;
                font-weight: bold;
                margin: 0 auto;
      /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
      ul.MenuBarActive
                z-index: 1000;
      /* Menu item containers, position children relative to this container and are a fixed width */
      ul.MenuBarHorizontal li
                margin: 0;
                padding: 0;
                font-size: 100%;
                position: relative;
                text-align: left;
                cursor: pointer;
                width: 18%;
                float: left;
      /* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
      ul.MenuBarHorizontal ul
                margin: 0;
                padding: 0;
                font-size: 100%;
                z-index: 1020;
                cursor: default;
                width: 80%;
                position: absolute;
                left: -1000em;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
                left: auto;
      /* Menu item containers are same fixed width as parent */
      ul.MenuBarHorizontal ul li
                width: 100%;
      /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
      ul.MenuBarHorizontal ul ul
                position: absolute;
                margin: -5% 0 0 95%;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
                left: auto;
                top: 0;
      DESIGN INFORMATION: describes color scheme, borders, fonts
      /* Submenu containers have borders on all sides */
                border: 1px solid #CCC;
      /* Menu items are a light gray block with padding and no text decoration */
      ul.MenuBarHorizontal a
                display: block;
                cursor: pointer;
                background-color: #EEE;
                padding: 0.5em 0.75em;
                color: #333;
                text-decoration: none;
      /* Menu items that have mouse over or focus have a blue background and white text */
      ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
                background-color: #33C;
                color: #FFF;
      /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
      ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
                color: #FFF;
      SUBMENU INDICATION: styles if there is a submenu under a given menu item
      /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
                background-image: url(SpryMenuBarDown.gif);
                background-repeat: no-repeat;
                background-position: 95% 50%;
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
                background-image: url(SpryMenuBarRight.gif);
      /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
                background-image: url(SpryMenuBarDownHover.gif);
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
                background-image: url(SpryMenuBarRightHover.gif);
      BROWSER HACKS: the hacks below should not be changed unless you are an expert
      /* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
      ul.MenuBarHorizontal iframe
                position: absolute;
                z-index: 1010;
                filter:alpha(opacity:0.1);
      /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
      @media screen, projection
                ul.MenuBarHorizontal li.MenuBarItemIE
                          display: inline;
                          f\loat: left;
                          background: #FFF;
        • 1. Re: Center spry menu
          BenPleysier Adobe Community Professional & MVP
          Try
          <!doctype html>
          <html>
          <head>
          <meta charset="utf-8">
          <title>Untitled Document</title>
          <link href="SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet">
          <style>
          ul.MenuBarHorizontal {
              max-width: 50em; /* change to suit */
              margin: auto;
          ul.MenuBarHorizontal li {
             width: 25%; /* 4 main menu items x 25% = 100% */
          </style>
          </head>
          <body>
          <ul id="MenuBar1" class="MenuBarHorizontal">
            <li><a class="MenuBarItemSubmenu" href="#">Item 1</a>
              <ul>
                <li><a href="#">Item 1.1</a></li>
                <li><a href="#">Item 1.2</a></li>
                <li><a href="#">Item 1.3</a></li>
              </ul>
            </li>
            <li><a href="#">Item 2</a></li>
            <li><a class="MenuBarItemSubmenu" href="#">Item 3</a>
              <ul>
                <li><a class="MenuBarItemSubmenu" href="#">Item 3.1</a>
                  <ul>
                    <li><a href="#">Item 3.1.1</a></li>
                    <li><a href="#">Item 3.1.2</a></li>
                  </ul>
                </li>
                <li><a href="#">Item 3.2</a></li>
                <li><a href="#">Item 3.3</a></li>
              </ul>
            </li>
            <li><a href="#">Item 4</a></li>
          </ul>
          <script src="SpryAssets/SpryMenuBar.js"></script>
          <script>
          var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", {imgDown:"SpryAssets/SpryMenuBarDownHover.gif", imgRight:"SpryAssets/SpryMenuBarRightHover.gif"});
          </script>
          </body>
          </html>
