1 Reply Latest reply on Jan 15, 2014 8:47 AM by c.pfaffenbichler
    Create images with dynamic width from 3 images each (left/center/right-part)
    Broken Pictures
      Hello,
      i want to employ a script to create images of dynamic width for me. The whole process shall base on different sized sets of images, which contain a left-image, a right-image and a center-image. The desired width for the different cases shall be reached by duplicating the center-image between the two outer images and placing those images next to each other until the image extends to desired width.
      The layers importet into Photoshop shall be importet as smart-layers (which i already solved).
      Has anyone done something similar already and could give me some useful hints on that issue ?
      I have come up to this until now:
      #target Photoshop
       // =========================== Opens a new document and asks for dimensions ============================
      var myLayerset = File.openDialog ("Select the set of images you want to use!", "*.png",true)
      var myName = prompt("How do you want to call the document?"); // askes for document name
      var width =  prompt("Please insert width for the output here!", ""); // askes for desired width
      var height = prompt("Please insert height for the output here!", ""); //askes for desired height
      var docName = myName +".psd"
      var idMk = charIDToTypeID( "Mk  " );
          var desc3 = new ActionDescriptor();
          var idNw = charIDToTypeID( "Nw  " );
              var desc4 = new ActionDescriptor();
              var idNm = charIDToTypeID( "Nm  " );
              desc4.putString( idNm, """Wunschname""" );
              var idMd = charIDToTypeID( "Md  " );
              var idRGBM = charIDToTypeID( "RGBM" );
              desc4.putClass( idMd, idRGBM );
              var idWdth = charIDToTypeID( "Wdth" );
              var idRlt = charIDToTypeID( "#Rlt" );
              desc4.putUnitDouble( idWdth, idRlt, width );
              var idHght = charIDToTypeID( "Hght" );
              desc4.putUnitDouble( idHght, idRlt, height );
              var idRslt = charIDToTypeID( "Rslt" );
              var idRsl = charIDToTypeID( "#Rsl" );
              desc4.putUnitDouble( idRslt, idRsl, 72.000000 );
              var idpixelScaleFactor = stringIDToTypeID( "pixelScaleFactor" );
              desc4.putDouble( idpixelScaleFactor, 1.000000 );
              var idFl = charIDToTypeID( "Fl  " );
              var idTrns = charIDToTypeID( "Trns" );
              desc4.putEnumerated( idFl, idFl, idTrns );
              var idDpth = charIDToTypeID( "Dpth" );
              desc4.putInteger( idDpth, 8 );
              var idprofile = stringIDToTypeID( "profile" );
              desc4.putString( idprofile, """sRGB IEC61966-2.1""" );
          var idDcmn = charIDToTypeID( "Dcmn" );
          desc3.putObject( idNw, idDcmn, desc4 );
      executeAction( idMk, desc3, DialogModes.NO );
      //==============================================save document================================================
      var idsave = charIDToTypeID( "save" );
          var idAs = charIDToTypeID( "As  " );
              var desc5 = new ActionDescriptor();
              var idmaximizeCompatibility = stringIDToTypeID( "maximizeCompatibility" );
              desc5.putBoolean( idmaximizeCompatibility, true );
          var idPhtthree = charIDToTypeID( "Pht3" );
          desc4.putObject( idAs, idPhtthree, desc5 );
          var idIn = charIDToTypeID( "In  " );
          desc4.putPath( idIn, new File( "C:\\Users\\ target folder goes here" + docName ) );
          var idDocI = charIDToTypeID( "DocI" );
          desc4.putInteger( idDocI, 308 );
          var idsaveStage = stringIDToTypeID( "saveStage" );
          var idsaveStageType = stringIDToTypeID( "saveStageType" );
          var idsaveSucceeded = stringIDToTypeID( "saveSucceeded" );
          desc4.putEnumerated( idsaveStage, idsaveStageType, idsaveSucceeded );
      executeAction( idsave, desc4, DialogModes.NO );
      for (var i = 0; i < myLayerset.length; i++) {
      if (myLayerset[i] instanceof File && myLayerset[i].hidden == false) {
       // ======================================================= opens selected images as smart objects====================
      var idOpn = charIDToTypeID( "Opn " );
          var desc1 = new ActionDescriptor();
          var idnull = charIDToTypeID( "null" );
         desc1.putPath( idnull, myLayerset[i]);
          var idsmartObject = stringIDToTypeID( "smartObject" );
          desc1.putBoolean( idsmartObject, true );
      executeAction( idOpn, desc1, DialogModes.NO );
      //===================================duplicates opened layer into created document========================================
      var idDplc = charIDToTypeID( "Dplc" );
          var desc144 = new ActionDescriptor();
              var ref135 = new ActionReference();
              var idLyr = charIDToTypeID( "Lyr " );
              var idOrdn = charIDToTypeID( "Ordn" );
              var idTrgt = charIDToTypeID( "Trgt" );
              ref135.putEnumerated( idLyr, idOrdn, idTrgt );
          desc144.putReference( idnull, ref135 );
          var idT = charIDToTypeID( "T   " );
              var ref136 = new ActionReference();
              ref136.putName( idDcmn, docName);
          desc144.putReference( idT, ref136 );
          var idVrsn = charIDToTypeID( "Vrsn" );
          desc144.putInteger( idVrsn, 5 );
      executeAction( idDplc, desc144, DialogModes.NO );
      // ======================================================= close tab without saving ==========
      var idCls = charIDToTypeID( "Cls " );
          var desc156 = new ActionDescriptor();
          var idSvng = charIDToTypeID( "Svng" );
          var idYsN = charIDToTypeID( "YsN " );
          var idN = charIDToTypeID( "N   " );
          desc156.putEnumerated( idSvng, idYsN, idN );
      executeAction( idCls, desc156, DialogModes.NO );
        • 1. Re: Create images with dynamic width from 3 images each (left/center/right-part)
          c.pfaffenbichler Level 9
          I adapted a Script somewhat, so you may give this a test.
          But it uses the open file so you would have to adapt it further.
          // arranges the selected jpg, tif, psd in line;
          // gutters may be irregular due to rounding effects;
          // thanks to michael l hale and muppet mark;
          // for mac and CS6;
          // 2014, use it at your own risk;
          #target photoshop
          if (app.documents.length == 0) {
                    var myDocument = app.documents.add(UnitValue (300, "mm"), UnitValue (50, "mm"), 300, "new", NewDocumentMode.RGB, DocumentFill.TRANSPARENT)
          else {myDocument = app.activeDocument};
          // set to pixels;
          var originalRulerUnits = app.preferences.rulerUnits;
          app.preferences.rulerUnits = Units.PIXELS;
          var theArray = [0, 0, myDocument.width, myDocument.height];
          // select files;
          if ($.os.search(/windows/i) != -1) {var theFiles = File.openDialog ("please select files", '*.jpg;*.tif;*.pdf;*.psd', true)}
          else {var theFiles = File.openDialog ("please select exactly three files", getFiles, true)};
          // do the arrangement
          if (theFiles) {placeInLines (myDocument, theFiles, theArray)}
          app.preferences.rulerUnits = originalRulerUnits;
          ////// function to place images in lines //////
          function placeInLines (myDocument, theFiles, theArray) {
          theFiles.sort();
          // fit on screen;
          var idslct = charIDToTypeID( "slct" );
          var desc64 = new ActionDescriptor();
          var ref44 = new ActionReference();
          var idMn = charIDToTypeID( "Mn  " );
          var idMnIt = charIDToTypeID( "MnIt" );
          var idFtOn = charIDToTypeID( "FtOn" );
          ref44.putEnumerated( idMn, idMnIt, idFtOn );
          desc64.putReference( idnull, ref44 );
          executeAction( idslct, desc64, DialogModes.NO );
          // change pref;
          setToAccelerated();
          app.togglePalettes();
          var check = turnOffRescale ();
          // create the arrangement;
          if (theFiles.length > 0 && theFiles.length == 3) {
          myDocument.activeLayer = myDocument.layers[0];
          // create masked group;
          var theGroup = myDocument.layerSets.add();
          theGroup.name = "arrangement";
          // determine the array’s values;
          var areaWidth = theArray[2] - theArray[0];
          var areaHeight = theArray[3] - theArray[1];
          var theDocResolution = myDocument.resolution;
          var areaRelation = areaHeight / areaWidth;
          // center of placed non-pdf images;
          var centerX = Number(myDocument.width / 2);
          var centerY = Number(myDocument.height / 2);
          // suppress dialogs;
          var theDialogSettings = app.displayDialogs;
          app.displayDialogs = DialogModes.NO;
          var pdfSinglePages = new Array;
          var nonPDFs = new Array;
          var theDimPDFs = new Array;
          var theLength = 0;
          // collect the files’ measurements;
          var theDimensions = new Array;
          var theLengths = new Array;
          // array to collect both files and placed pdf-pages;
          var theseFiles = new Array;
          var theLength = 0;
          for (var o = 0; o < theFiles.length; o++) {
              var thisFile = theFiles[o];
                    theseFiles.push(thisFile);
                    var theDim = getDimensions(thisFile);
                    theDimensions.push(theDim);
                    theRelativeWidth = 100 / theDim[1] * theDim[0];
                    theLength = theLength + theRelativeWidth;
          // reset dialogmodes;
          app.displayDialogs = DialogModes.ERROR;
          // if three files;
          if (theseFiles.length == 3) {
          // create the layers;
          var theNumber = 0;
          var theAdded = 0;
          var y = areaHeight / 2;
          // add placed image’s width;
          var thisLineWidth = 0 + theAdded;
          var theLastFactor = Number (Number(myDocument.height) / theDimensions[2][1] * theDimensions[2][2] / theDocResolution * 100);
          var theLastWidth = Math.round(theDimensions[2][0] * theLastFactor / 100 * theDocResolution / theDimensions[2][2]);
          // place the files;
          for (var x = 0; x < 3; x++) {
          var theNumber = x;
          var thisFile = theseFiles[theNumber];
          var theFactor = Number (Number(myDocument.height) / theDimensions[theNumber][1] * theDimensions[theNumber][2] / theDocResolution * 100);
          var theNewWidth = Math.round(theDimensions[theNumber][0] * theFactor / 100 * theDocResolution / theDimensions[theNumber][2]);
          var offsetX = theNewWidth / 2 + thisLineWidth - centerX + theArray[0];
          var offsetY = y - centerY + theArray[1];
          var theLayer = placeScaleFile (thisFile, offsetX, offsetY, theFactor, theFactor);
          myDocument.activeLayer.move(theGroup, ElementPlacement.PLACEATBEGINNING);
          thisLineWidth = thisLineWidth + theNewWidth;
          // duplicate the middle one;
          if (theNumber == 1) {
                    while (thisLineWidth < myDocument.width - theLastWidth) {
                              theLayer = duplicateAndOffset (theLayer, theNewWidth, 0);
          // reset;
          turnOnRescale (check);
          ////// playback to accelerated //////
          function setToAccelerated () {
                    var idsetd = charIDToTypeID( "setd" );
                              var ref1 = new ActionReference();
                              var idPrpr = charIDToTypeID( "Prpr" );
                              var idPbkO = charIDToTypeID( "PbkO" );
                              ref1.putProperty( idPrpr, idPbkO );
                              var idcapp = charIDToTypeID( "capp" );
                              ref1.putEnumerated( idcapp, idOrdn, idTrgt );
                    desc1.putReference( idnull, ref1 );
                              var desc2 = new ActionDescriptor();
                              var idperformance = stringIDToTypeID( "performance" );
                              var idaccelerated = stringIDToTypeID( "accelerated" );
                              desc2.putEnumerated( idperformance, idperformance, idaccelerated );
                    desc1.putObject( idT, idPbkO, desc2 );
                    executeAction( idsetd, desc1, DialogModes.NO );
          ////// get psds, tifs and jpgs from files //////
          function getFiles (theFile) {
              if (theFile.name.match(/\.(jpg|tif|psd|pdf|)$/i)) {
                  return true
          ////// place //////
          function placeScaleFile (file, xOffset, yOffset, theScale) {
          var idPlc = charIDToTypeID( "Plc " );
              desc5.putPath( idnull, new File( file ) );
              var idFTcs = charIDToTypeID( "FTcs" );
              var idQCSt = charIDToTypeID( "QCSt" );
              var idQcsa = charIDToTypeID( "Qcsa" );
              desc5.putEnumerated( idFTcs, idQCSt, idQcsa );
              var idOfst = charIDToTypeID( "Ofst" );
                  var desc6 = new ActionDescriptor();
                  var idHrzn = charIDToTypeID( "Hrzn" );
                  var idPxl = charIDToTypeID( "#Pxl" );
                  desc6.putUnitDouble( idHrzn, idPxl, xOffset );
                  var idVrtc = charIDToTypeID( "Vrtc" );
                  desc6.putUnitDouble( idVrtc, idPxl, yOffset );
              desc5.putObject( idOfst, idOfst, desc6 );
              var idPrc = charIDToTypeID( "#Prc" );
              desc5.putUnitDouble( idWdth, idPrc, theScale );
              desc5.putUnitDouble( idHght, idPrc, theScale );
              var idLnkd = charIDToTypeID( "Lnkd" );
              desc5.putBoolean( idLnkd, true );
          executeAction( idPlc, desc5, DialogModes.NO );
          return myDocument.activeLayer;
          ////// open pdf //////
          function openPDF (theImage, x) {
          // define pdfopenoptions;
          var pdfOpenOpts = new PDFOpenOptions;
          pdfOpenOpts.antiAlias = true;
          pdfOpenOpts.bitsPerChannel = BitsPerChannelType.EIGHT;
          pdfOpenOpts.cropPage = CropToType.TRIMBOX;
          pdfOpenOpts.mode = OpenDocumentMode.CMYK;
          pdfOpenOpts.resolution = 10;
          pdfOpenOpts.suppressWarnings = true;
          pdfOpenOpts.usePageNumber  = true;
          pdfOpenOpts.page = x;
          var thePdf = app.open(theImage, pdfOpenOpts);
          thePdf.close(SaveOptions.DONOTSAVECHANGES);
          app.displayDialogs = theDialogSettings;
          ////// turn off preference to scale placed image //////
          function turnOffRescale () {
          // determine if the resize prefernce is on;
          var ref = new ActionReference();
          ref.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
          var appDesc = executeActionGet(ref);
          var prefDesc = appDesc.getObjectValue(charIDToTypeID( "GnrP" ));
          var theResizePref = prefDesc.getBoolean(stringIDToTypeID( "resizePastePlace" ));
          // turn off resize image during place;
          if (theResizePref == true);{
              var desc12 = new ActionDescriptor();
                  var ref4 = new ActionReference();
                  var idGnrP = charIDToTypeID( "GnrP" );
                  ref4.putProperty( idPrpr, idGnrP );
                  ref4.putEnumerated( idcapp, idOrdn, idTrgt );
              desc12.putReference( idnull, ref4 );
                  var desc13 = new ActionDescriptor();
                  var idresizePastePlace = stringIDToTypeID( "resizePastePlace" );
                  desc13.putBoolean( idresizePastePlace, false );
              desc12.putObject( idT, idGnrP, desc13 );
          executeAction( idsetd, desc12, DialogModes.NO );
          return theResizePref
          ////// turn on preference to scale plced image //////
          function turnOnRescale (check) {
          if (check == true) {
              var desc14 = new ActionDescriptor();
                  var ref5 = new ActionReference();
                  ref5.putProperty( idPrpr, idGnrP );
                  ref5.putEnumerated( idcapp, idOrdn, idTrgt );
              desc14.putReference( idnull, ref5 );
                  var desc15 = new ActionDescriptor();
                  desc15.putBoolean( idresizePastePlace, true );
              desc14.putObject( idT, idGnrP, desc15 );
          executeAction( idsetd, desc14, DialogModes.NO );
          ////// convert to so if not one aready //////
          function duplicateAndOffset (theLayer, theXOffset, theYOffset) {
          app.activeDocument.activeLayer = theLayer;
          var idcopy = charIDToTypeID( "copy" );
              var desc9 = new ActionDescriptor();
                  ref5.putEnumerated( idLyr, idOrdn, idTrgt );
              desc9.putReference( idnull, ref5 );
                  var desc10 = new ActionDescriptor();
                  var idRlt = charIDToTypeID( "#Pxl" );
                  desc10.putUnitDouble( idHrzn, idRlt, theXOffset );
                  desc10.putUnitDouble( idVrtc, idRlt, theYOffset );
              desc9.putObject( idT, idOfst, desc10 );
          executeAction( idcopy, desc9, DialogModes.NO );
          return app.activeDocument.activeLayer
          ////// load pdf as smart object //////
          function transformLayer (layer, percentage, xOffset, yOffset) {
          app.activeDocument.activeLayer = layer;
          var idTrnf = charIDToTypeID( "Trnf" );
              desc4.putEnumerated( idFTcs, idQCSt, idQcsa );
                  desc5.putUnitDouble( idHrzn, idPxl, xOffset );
                  desc5.putUnitDouble( idVrtc, idPxl, yOffset );
              desc4.putObject( idOfst, idOfst, desc5 );
              desc4.putUnitDouble( idWdth, idPrc, percentage );
              desc4.putUnitDouble( idHght, idPrc, percentage );
              desc4.putBoolean( idLnkd, true );
              var idAntA = charIDToTypeID( "AntA" );
              desc4.putBoolean( idAntA, true );
          executeAction( idTrnf, desc4, DialogModes.NO );
          ////// function to get file’s dimensions, thanks to michael l hale //////
          function getDimensions( file ){
          function divideString (theString) {
                    theString = String(theString);
              var a = Number(theString.slice(0, theString.indexOf("\/")));
              var b = Number(theString.slice(theString.indexOf("\/") + 1));
              return (a / b)
          // from a script by michael l hale;
          function loadXMPLibrary(){
               if ( !ExternalObject.AdobeXMPScript ){
                    try{
                         ExternalObject.AdobeXMPScript = new ExternalObject
        ('lib:AdobeXMPScript');
                    }catch (e){
                         alert( ErrStrs.XMPLIB );
                         return false;
               return true;
          function unloadXMPLibrary(){
             if( ExternalObject.AdobeXMPScript ) {
                try{
                   ExternalObject.AdobeXMPScript.unload();
                   ExternalObject.AdobeXMPScript = undefined;
                }catch (e){
          ////// based on a script by muppet mark //////
          function dimensionsShellScript (file) {
                    try {
          // getMetaDataMDLS;
          if (File(file) instanceof File && File(file).exists) {
                    var shellString = "/usr/bin/mdls ";
                    shellString += File(file).fsName;
          //          shellString += File(file).fullName;
                    shellString += ' > ~/Documents/StdOut2.txt';
                    app.system(shellString);
          // read the file;
          if (File('~/Documents/StdOut2.txt').exists == true) {
              var file = File('~/Documents/StdOut2.txt');
              file.open("r");
              file.encoding= 'BINARY';
              var theText = new String;
              for (var m = 0; m < file.length; m ++) {
                              theText = theText.concat(file.readch());
                    file.close();
                    theText = theText.split("\n");
          // get the dimensions;
                    var dim = new Array;
                    for (var m = 0; m < theText.length; m++) {
                              var theLine = theText[m];
                              if (theLine.indexOf("kMDItemPixelWidth") != -1) {dim.push(theLine.match(/[\d\.]+/g).join("") )}
                              if (theLine.indexOf("kMDItemPixelHeight") != -1) {dim.push(theLine.match(/[\d\.]+/g).join("") )}
                              if (theLine.indexOf("kMDItemResolutionWidthDPI") != -1) {dim.push(theLine.match(/[\d\.]+/g).join("") )}
                              if (theLine.indexOf("kMDItemResolutionHeightDPI") != -1) {dim.push(theLine.match(/[\d\.]+/g).join("") )}
          // remove file and hand back;
                    File('~/Documents/StdOut2.txt').remove();
          catch (e) {
                    if (File('~/Documents/StdOut2.txt').exists == true) {File('~/Documents/StdOut2.txt').remove()};
                    return dim
                    try{
                              loadXMPLibrary();
                              var xmpf = new XMPFile( file.fsName, XMPConst.UNKNOWN, XMPConst.OPEN_FOR_READ );
                              var xmp = xmpf.getXMP();
                              xmpf.closeFile();
                              var resolutionUnit = xmp.getProperty( XMPConst.NS_TIFF, 'ResolutionUnit', XMPConst.STRING);
                              var resFactor = 1;
                              if (resolutionUnit == 2) {
                                        var resFactor = 1;
                              if (resolutionUnit == 3) {
                                        var resFactor = 2.54;
                              var dim = [xmp.getProperty( XMPConst.NS_EXIF, 'PixelXDimension', XMPConst.STRING),
                              xmp.getProperty( XMPConst.NS_EXIF, 'PixelYDimension', XMPConst.STRING),
                              divideString (xmp.getProperty( XMPConst.NS_TIFF, 'XResolution', XMPConst.STRING)) * resFactor,
                              divideString (xmp.getProperty( XMPConst.NS_TIFF, 'YResolution', XMPConst.STRING)) * resFactor];
                              unloadXMPLibrary();
                              if(dim[0]=="undefined" || dim[1]=="undefined"){
                      var dim = undefined;
                      var res = undefined;
                      var bt = new BridgeTalk;
                      bt.target = "bridge";
                      var myScript = ("var ftn = " + psRemote.toSource() + "; ftn("+file.toSource()+");");
                      bt.body = myScript;
                      bt.onResult = function( inBT ) {myReturnValue(inBT.body); }
                      bt.send(10);
                              function myReturnValue(str){
                                        res = str;
                                        dim = str.split(',');
                              function psRemote(file){
                                        var t= new Thumbnail(file);
                                        return t.core.quickMetadata.width+','+t.core.quickMetadata.height;
              }catch(e){unloadXMPLibrary()};
                    if (String(dim[2]).indexOf("\/") != -1) {
                              var a = divideString(dim[2]);
                              var b = divideString(dim[3]);
                              dim = [dim[0], dim[1], a, b]
          // if dimensions are missing as might be the case with some bitmap tiffs for example try a shell-script;
                    if (dim[0] == undefined || dim[1] == undefined) {
                              var array = dimensionsShellScript(file);
                              dim = array;
          // if shell-string failed open doc to get measurements;
                              var thisDoc = app.open (File(file));
          // close ai without saving;
                              if (file.name.slice(-3).match(/\.(ai)$/i)) {
                                        thisDoc.trim(TrimType.TRANSPARENT);
                                        var dim = [thisDoc.width, thisDoc.height, thisDoc.resolution, thisDoc.resolution];
                                        thisDoc.close(SaveOptions.DONOTSAVECHANGES)
                              else {
                                        thisDoc.close(SaveOptions.PROMPTTOSAVECHANGES)
          return dim;
