1. Re: My audio levels barely increase at all when adjusting in the timeline
joe bloe premiere Jan 10, 2014 7:15 AM (in response to spdorsey6969)Try:
Right-Click the audio clip in the Timeline and increase the Gain.
This will increase the available adjustment range with the 'rubber band'.
2. Re: My audio levels barely increase at all when adjusting in the timeline
Peru Bob Jan 10, 2014 10:10 AM (in response to spdorsey6969)And if joe's solution doesn't give you enough gain, duplicate the audio to another track. The result will be additive.
3. Re: My audio levels barely increase at all when adjusting in the timeline
joe bloe premiere Jan 10, 2014 10:23 AM (in response to Peru Bob)Duplicating the track could potentially introduce phasing problems.
Increasing the clip's Audio Gain is a much safer approach,
and will give as much gain as you want... to the point of overmodulation.
Another advantage of increasing the clip's Audio Gain
is the waveforms will vertically expand and will be easier to see.
4. Re: My audio levels barely increase at all when adjusting in the timeline
Peru Bob Jan 10, 2014 10:28 AM (in response to joe bloe premiere)How will phasing be a problem if the tracks are identical and aligned exactly?
5. Re: My audio levels barely increase at all when adjusting in the timeline
joe bloe premiere Jan 10, 2014 10:33 AM (in response to Peru Bob)By the tracks being identical and aligned exactly.
Have you never experienced phase cancellation before?
And the contention that adjusting the Audio Gain of a clip
might not provide enough gain is a fallacy.
And... why go through the extra steps of duplicating a track
when all you have to do is input a clip Gain level and be done?
6. Re: My audio levels barely increase at all when adjusting in the timeline
Peru Bob Jan 10, 2014 10:34 AM (in response to joe bloe premiere)No I haven't. At least I don't know that I have. This is just a hobby for me. I know I could Google it, but I wonder if you could point me in the right direction on what to search for in Google to learn more about that.
8. Re: My audio levels barely increase at all when adjusting in the timeline
Peru Bob Jan 10, 2014 10:46 AM (in response to joe bloe premiere)I can understand how different sources (different mics or tracks, for example) can result in phase cancellation. What I can't understand is why two identical tracks can have a phase shift, unless you are saying that when a clip is placed in the timeline its position is not really precise.
9. Re: My audio levels barely increase at all when adjusting in the timeline
joe bloe premiere Jan 10, 2014 11:00 AM (in response to Peru Bob)I can understand how different sources (different mics or tracks, for example) can result in phase cancellation.
That would not create phase cancellation.
..unless you are saying that when a clip is placed in the timeline its position is not really precise.
I am not saying that at all.
Notice I used the words "...could potentially..." in post #3.
Why tempt fate by using a cumbersome method of increasing
a clip's Gain by duplicating a track when the potential implications
are not fully understood?
10. Re: My audio levels barely increase at all when adjusting in the timeline
Peru Bob Jan 10, 2014 11:08 AM (in response to joe bloe premiere)So you mean it's easy to make a mistake by not having them identical and aligned exactly.
I don't dispute that using the audio gain method is best. My experiance with one version of Premiere Elements did not allow me to increase the gain enough without duplicating the tracks. I was not aware tha Premiere Pro did not have that limitation.
11. Re: My audio levels barely increase at all when adjusting in the timeline
joe bloe premiere Jan 10, 2014 11:09 AM (in response to Peru Bob)So you mean it's easy to make a mistake by not having them identical and aligned exactly.
No.
12. Re: My audio levels barely increase at all when adjusting in the timeline
JSS1138 Jan 10, 2014 4:12 PM (in response to spdorsey6969)I cannot increase them much higher than 12.
You actually can't add more than 6dB of Volume. This is all PP offers. The Gain parameter is the best way to get more.
13. Re: My audio levels barely increase at all when adjusting in the timeline
spdorsey6969 Jan 10, 2014 6:01 PM (in response to spdorsey6969)Thank you all for your answers. Increasing the gain helped a great deal.
