5 Replies Latest reply on Jan 14, 2014 11:06 AM by elainecc
    Cannot delete dynamically created symbols.
    jpringles Level 1
      I have a dynamically created symbol going into a parent div. not the Stage.
      using:
      var water = sym.createChildSymbol("water", "water_pos", 0);
      var fishing = sym.createChildSymbol("fishing_boat", "fishing_boat_pos", 1);
      I need 4 animated scenes but only showing one at a time. It was runnng slowly if left running for a while (which is also strange) so I'm trying to only load what I need.
      The symbols are creating perfectly but for some reason I cannot delete them whan i'm finished with them.
      I can delete the other symbols that were not dynamically created in the project but cannot single out the new instances of symbols and delete them.
      I am using the deleteSymbol() API.
      I have tried the correct answer here but it is deleteing my whole screen leaving a white BG??
      They suggest:
      You use pass the symbol to be deleted in as the parameter for the deleteSymbol() method, like so:
      sym.deleteSymbol("Peak1_1");
      http://forums.adobe.com/message/5283417#5283417
      I'm Bamboozled!
      What am I missing!
      Thanks for any help or suggestions.
      Johnny
        • 1. Re: Cannot delete dynamically created symbols.
          elainecc Adobe Employee
          Try:
          water.deleteSymbol();
          fishing.deleteSymbol();
          -Elaine
          • 2. Re: Cannot delete dynamically created symbols.
            jpringles Level 1
            Thank for the suggestion Elaine.
            I tried that code on a button when clicked but it didn't work.
            I also tried it on a trigger and it didn't work.
            Nothing happens at all.
            You said on a different thread I need to "maintain a reference to the symbols after you create them" so I can delete them.
            How would I do that? How do I hard code the name of the symbol as suggested in the link below?
            http://forums.adobe.com/message/5328248#5328248#5328248
            My symbols are not nested symbols. They are on the stage and being called to a div on the stage when created.
            • 3. Re: Cannot delete dynamically created symbols.
              jpringles Level 1
              HI elaine.
              I have also tried your suggestion on another thread (http://forums.adobe.com/thread/1262104) where you are creating a reference to the symbol on creation but still no Luck!!
              I created a new project just to test this. I have one symbol called "sym" and one div called "pos" that i'm creating the symbol in.
              Create:
              var test = sym.createChildSymbol("sym", "pos");
              sym.setVariable("var1", "test"); ..................................(your example didn't have inverted commas on "test". sym.setVariable("bar", foo);) no sure which is correct.
              Delete:
              var test = sym.getParentSymbol().getSymbol("sym").getVariable("var1");
              test.deleteSymbol();
              I tried instead of getting the parentSymbol:
              var test = sym.getComposition().getStage().getSymbol("sym").getVariable("var1");
              and:
              var test = sym.getSymbol("sym").getVariable("var1");
              Still no luck!
              • 4. Re: Cannot delete dynamically created symbols.
                jpringles Level 1
                I found the solution from timjamarillo over on this thread: http://forums.adobe.com/message/4848076
                I took me a while to find it so i'll put it here in case anyone else needs it!!
                It's probably a scope issue. I recommend putting all functional code on Stage.compositionReady event, then calling those functions from wherever you need them.
                Put this code on Stage.compositionReady:
                // store your symbol
                sym.mySymbol;
                sym.createParticle = function(){
                             // pull symbol from library, add to Stage
                             sym.mySymbol = sym.createChildSymbol("Food_Spanner", "Stage");
                sym.removeParticle = function(){
                     // delete symbol
                     sym.mySymbol.deleteSymbol();
                Put this code on frame 1:
                sym.getComposition().getStage().createParticle();
                Put this code on frame 15:
                sym.getComposition().getStage().removeParticle();
                • 5. Re: Cannot delete dynamically created symbols.
                  Glad you worked it out!
                  -Elaine
