13 Replies Latest reply on Jan 11, 2014 8:53 AM by Peter Spier
    InDesign to PDF
    MikeRM
      When you print to PDF in ID, where does the unnamed file go?
        • 1. Re: InDesign to PDF
          Interesting question. Im not sure it's ever more than a phqntom file in memory, tossed when the distiller is done with it.
          But why print to PDF at all? Other than Print Booklet, there's pretty much no reason to make PDF other than by export.
          • 2. Re: InDesign to PDF
            MikeRM Level 1
            Peter,
            Export is great—most of the time. But, when I need to print in reverse order or only a select few pages (or perhaps only the odd pages) Export does not have the functions.
            • 3. Re: InDesign to PDF
              Ummmm,
              You can just easily as input a range for exporting a few pages as you can for printing them, and if you want reversed order, odds or evens you can specify that in Acrobat when you print the PDF.
              I certainly don't care if yo prefer distillled PDF, but you give up certain things to get it.
              • 4. Re: InDesign to PDF
                John Mensinger Adobe Community Professional & MVP
                I agree that there is rarely a compelling reason to print to PDF, (or even an actual printer!) from InDesign. But if you insist, there is a setting in the Adobe PDF print driver where you can choose "prompt for PDF file name." Set it to that as the default, and you'll always maintain control over the output file's name and location.
                • 5. Re: InDesign to PDF
                  John,
                  I may have misunderstood, but I think the question was where is the postcript that gets distilled stored, not the final PDF.
                  • 6. Re: InDesign to PDF
                    You could be right, I don't know. The original post says "print to PDF" so that's what I addressed. Now it's covered either way.
                    • 7. Re: InDesign to PDF
                      This exports the odd pages of my 8 page doc backwards:
                      • 8. Re: InDesign to PDF
                        MikeRM Level 1
                        Rob,
                        That should work. Might be interesting with 100+ page books, but it will work.
                        • 9. Re: InDesign to PDF
                          If it's something you do a lot of the range field is scriptable. This Applescript sets the range to the document's odd pages
                          tell application "Adobe InDesign CS6"
                              set p to ""
                              repeat with i from 1 to count of pages of active document
                                  --change 1 to 0 for even pages
                                  if i mod 2 is 1 then
                                      set p to p & i & ", " as string
                                  end if
                              end repeat
                              set p to characters 1 thru ((count of p) - 2) of p
                              set page range of PDF export preferences to (p as string)
                          end tell
                          • 10. Re: InDesign to PDF
                            Sandee Cohen Adobe Community Professional
                            Let me see if I can combine these answers into a single reply.
                            First, the question "When you Print to PDF, where does the unnamed file go?" is in error. There is no Print to PDF. There are two types of Export to PDF. One for interactive PDF and another for Print PDF.
                            If you choose those options, no unnamed file is created.
                            It sounds like you're remembering a workflow from some other application where a temporary PostScript file was generated and then converted into a PDF using Distiller. But all of that happened in the background.
                            Nowadays, few people use Distiller. However, as you point out, there is no option to print only odd or even pages using the Export to PDF dialog boxes.
                            So if you want to print only the odd pages of a book, you would need to enter each one manually, use Rob's script, or use the Print to PostScript dialog box. That gives you the option to choose odd or even pages.
                            Then, once you have the PS file, you use Distiller to convert it into a PDF.
                            However, there is no unnamed PS file. You name it and give it a destination as you would any other file.
                            • 11. Re: InDesign to PDF
                              Sandee,
                              Those of us with PCs still enjoy the installation of the PDF virtual printer -- the one-click ID-to-ps-to-distilled-PDF solution that disappeared for Mac users a couple of years ago, so for us there is still a "print tp PDF" option.
                              • 12. Re: InDesign to PDF
                                sorrentomesa
                                Also just a note to use caution when using Distiller since this will flatten native transparency possibly creating artifacts visible with high end output.
                                Exporting to PDF will always preserve native transparency thereby ensuring the best final product assuming your content is destined for print.
                                • 13. Re: InDesign to PDF
                                  Not quite. Distilling will always flatten transparency, rgardless of comapaibility settings, but Exporting only preserves it in versions of PDF that support it: Acrobat 5 or higher, so exporting to Acrobat 4 compatibility will also flatten.
