3 Replies Latest reply on Jan 14, 2014 12:57 PM by Josh_Corey
    Align check box to left margin
    pjhyland
      How do I align a check box to the left margin of a form, then type in my text to the right of the box?
        • 1. Re: Align check box to left margin
          Josh_Corey Adobe Employee
          Hi;
          Unfortunately that is not one of the options for the labels position.  The options for the "Label position" are Left aligned, Right aligned or Above the check box.
          Josh
          • 2. Re: Align check box to left margin
            pjhyland Level 1
            What if we want a check box, and then text?  I don't even see the point of a "label" for each check box.  Example:
            SELECT ALL THAT APPLY:
            __ I took the course twice, and each time received a substandard grade (D, F, or NP).
            __ There has been a significant lapse of time since I last took this class.
            __ I want to repeat this class despite receiving a satisfactory grade.
            • 3. Re: Align check box to left margin
              You could achieve what you show above with a Multiple Choice field with the label position "Above", the label would be "Select all that apply" and then the choices would be as you show, there isn't a label to the left of each option, the checkbox is on the left and the choice text on the right - this is the field I set up in FormsCentral:
              Josh
