3 Replies Latest reply on Feb 3, 2016 6:33 PM by christellep53501927
    Erreur au niveau du serveur d'autorisation
    Jihairbook
      Bjr,
      Je recontre un problème pour autoriser mon ordinateur, puis ma liseuse, car au moment de m'identifier sur ADE, je reçois le message suivant:
      " Erreur au niveau du serveur d'activation
      Code: E_AUTH_NOT_READY"
      Comment procéder? Merci d'avance.
        • 1. Re: Erreur au niveau du serveur d'autorisation
          sjpt Level 4
          Sometimes ADE gets its registration/activation confused and in a semi-authorized state.
          Uninstalling and reinstalling does not help, and indeed installation can even trigger this state.
          Unfortunately, it often then gives misleading error messages about what is wrong.
          A common incorrect message informs you that the ID is already in use on another computer and cannot be reused.
          Another is  "E_AUTH_NOT_READY"
          This can often be resolved by completely removing any authorization using ctrl-shift-D to the Library screen on ADE (cmd-shift-D if on Mac).
          Restart ADE, and then reauthorize with your (old) Adobe ID.
          In extreme cases on the mac, the following extra step has helped some people.  Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash. If you are using 10.7, see Access hidden user library files | Mac OS 10.7 Lion. http://forums.adobe.com/thread/1265248?tstart=0
          • 2. Re: Erreur au niveau du serveur d'autorisation
            louisem35059314
            I have somewhat the same issue, I cannot seem to unauthorize my computer - when asked for my password to get the unauthorization done, no matter what password I use I am told it is incorrect.  I have no idea what my password is, so I cannot use my e-reader.  My computer also does not seem to recognize that my e-reader (KOBO) is connected to my computer.
