Hello,
Where can I check to see the type of server that ColdFusion is configured to run currently? I have an existing installation of CF 9.0.1, which I will be removing and installing CF 9.0.2. During instalation of 9.0.2, I would need to specify the server to be used - ColdFusion server / Apache/ IIS etc. My question is, where should I see in the existing CF 9.0.1 to understand the server that is currently being used.
Thanks!
You could use the Web Server Configuration Tool. Assuming you are on Windows, the path to launch it is usually
Start => Programs => Adobe => ColdFusion 9 => Web Server Configuratiol Tool
In fact, you could use this tool to add or remove web servers.
