1. Re: Publish error: failed to create chr_book_op.gif
Anjaneai Srivastava Jan 16, 2014 7:18 AM (in response to celkins)Hi,
When the publish fails does it always indicate any resource file in the error like Failed to create FILENAME.
Can you try to generate WebHelp/FlashHelp both and see if the error is regarding the same files? Can you locate this particualr graphic in your project, is it broken or missing?
Also, create a test project and simply publish it to the same connection details in the same output and see if tehre is a problem with Robohelp not being able to connect to your FTP details.
Can you add a screenshot of the compilation/publishing summary that you see in the 'Output view'.
Anjaneai
2. Re: Publish error: failed to create chr_book_op.gif
celkins Jan 17, 2014 2:48 PM (in response to Anjaneai Srivastava)Hello Anjaneai,
I created a test project (as WebHelp). It generated correctly but again failed during Publish at the same file (chr_con_out.gif) that causes all of my other projects to fail. The .gif file is present in all of my projects and is part of the standard Chrisi skin. Here is a screenshot of the error:
I generated the same test project as FlashHelp. It generated correctly but failed during Publish. I don't use FlashHelp, so I don't know how to interpret the error. Here is a screenshot of the error:
There were no errors to indicate a problem with the FTP connection.
Thank you for your help.
Carol
3. Re: Publish error: failed to create chr_book_op.gif
Peter Grainge Jan 29, 2014 12:26 AM (in response to celkins)
