2 Replies Latest reply on Jan 12, 2014 3:34 PM by ShootZ85
    " Load files into stack" Crach photoshop CC since the last update
    ShootZ85
      Hello,
      I have a probleme since the last photoshop's update... I don't don't know if it's the update is the reason for this crach but I'm used to working with this module often "Load files into stack" but this is the first time since Friday that is photoshop bug and has to be the restart.
      Do you have a solution?
      Thank you in advance
        • 1. Re: " Load files into stack" Crach photoshop CC since the last update
          How is the Load Files into a Stack script failing on your machine. The Latest CC update was for Adobe CSXS Infrastructure 4 that one failed to install on my system.  The Script still works on my system as does Photoshop CC. I do not think that update would effect Photoshop scripts.
          My Photoshop shows it version a 14.1.2 what your  Photoshop version?
          • 2. Re: " Load files into stack" Crach photoshop CC since the last update
            ShootZ85 Level 1
            Thank you JJMack for your reply, sorry for my english.
            This is strange because I have to use this module 2-3 times a day and twice with more of 20 pictures
            I have copy all information for you :
            Version Adobe Photoshop : 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00) x64
            Système d'exploitation : Windows 8 64 bits
            Version : 6.2
            Architecture système : UC Intel Famille :6, modèle :10, niveau :9 avec MMX, SSE Entier, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
            Nombre de processeurs physiques : 4
            Vitesse du processeur : 2994 MHz
            Mémoire intégrée : 8064 Mo
            Mémoire libre : 1788 Mo
            Mémoire disponible pour Photoshop : 6990 Mo
            Mémoire utilisée par Photoshop : 70 %
            Taille de la mosaïque d'images : 0K
            Niveaux de mémoire cache de l'image : 0
            Affichage : 1
            Limites d'affichage : haut = 0, gauche = 0, bas = 1050, droite = 1680
            Dessin OpenGL : Activé.
            Anciens GPU OpenGL autorisés : Non détectés.
            Mode de dessin OpenGL : Avancé
            Mode OpenGL normal autorisé : Vrai.
            Mode OpenGL avancé autorisé : Vrai.
