4 Replies Latest reply on Jan 13, 2014 11:55 PM by Mi_D
    Delete All Object Style in documents
    creativejoan0425 Level 1
      I want to delete all object style named "Footer", it can run when I have one Master Page, but if I have a 2nd Master Page Accroding to 1st Master Page, it occur error and CS6 will quit automatically, is it CS6 bugs or my script is wrong? anyone can help?
      function ClearAllFooter(){
      app.findObjectPreferences = app.changeObjectPreferences = null;
      app.findChangeObjectOptions.includeFootnotes = true;
      app.findChangeObjectOptions.includeHiddenLayers = true;
      app.findChangeObjectOptions.includeLockedLayersForFind = true;
      app.findChangeObjectOptions.includeLockedStoriesForFind = true;
      app.findChangeObjectOptions.includeMasterPages = true;
      var oStyle = app.activeDocument.objectStyles.item("Footer");
      app.findObjectPreferences.appliedObjectStyles = oStyle;
      var found = app.findObject();
      for ( var f = 0; f < found.length; f++ ) {
          found[f].remove();
      ClearAllFooter();
        • 1. Re: Delete All Object Style in documents
          Kasyan Servetsky Level 5
          When you remove objects, you should move backwards, like so:
          for (var f = found.length-1; f >= 0; f--) {
          Alternatively, you can set the reverseOrder parameter to true:
          var found = app.findObject(true);
          • 2. Re: Delete All Object Style in documents
            I try to change the script, it also will quit the indesign
                found[f].remove();
            ClearAllFooter();
            version 2:
                found[f].remove();
            ClearAllFooter();
            version 3:
                found[f].remove();
            ClearAllFooter();
            • 3. Re: Delete All Object Style in documents
              When B Master not According to A Master, and put the footer inside both A and B, it ok, not error, it is still hv something I need to write?
              • 4. Re: Delete All Object Style in documents
                Mi_D Level 3
                try below code
                    found[f].appliedObjectStyle = myDoc.objectStyles.item (0);//replace footer style with none
                Mi_D
