1. Re: Scaling an image
Dsarchy Jan 13, 2014 8:05 AM (in response to skadoodle)This is more to do with your workflow.
Personally i just hit Cmd+Alt+i
2. Re: Scaling an image
skadoodle Jan 13, 2014 8:19 AM (in response to Dsarchy)Command, alt, i, brings up the image window. That's not what I want to do. Say I have a shape on a layer (other than a square). I simply want to select it, command T it, and then scale it up or down holding the shift key to constrain. But it doesn't do that. Looking at the calibrations I'll see something like w112.56, and h112.72. If I click on that chain link first, then it works but that's an extra step that shouldn't be necessary.
3. Re: Scaling an image
Dsarchy Jan 13, 2014 8:32 AM (in response to skadoodle)Uh, sorry misunderstood.
Odd its doing that I dont have that on mine (CC). Do you have snap to pixel option enabled in preferences?
4. Re: Scaling an image
skadoodle Jan 13, 2014 8:44 AM (in response to Dsarchy)Do you mean Snap Vector Tools and Transforms...? Yes, it's checked. Thanks so much for trying to help, btw. When you say you "don't have that on mine" you mean it works the way I'm describing it should work?
5. Re: Scaling an image
Dsarchy Jan 13, 2014 9:16 AM (in response to skadoodle)Try turning it off does it help? (i dont have it turned on this end and could be the reason for it doing it)
6. Re: Scaling an image
skadoodle Jan 13, 2014 9:34 AM (in response to Dsarchy)Yeah I tried turning off before replying to you. No difference. You're saying you don't have the same issue I have? A friend of mine has the same issue Ihave.
