0 Replies Latest reply on Jan 13, 2014 8:13 AM by KentWood2012
    Flex 4 bug:inherited propery cause transition bug
    KentWood2012 Level 1
      i try to make some foldable groups, like an accordion component
      i create a Base.as class and extends from Group,code like this
          package
                import flash.events.MouseEvent;
                import spark.components.Group;
                public class Base extends Group
                          public var header:Group;
                          public var body:Group;
                          public function Base()
                                    super();
                          override protected function initializationComplete():void
                                    super.initializationComplete();
                                    if(header)
                                              header.addEventListener(MouseEvent.CLICK,changeState);
                          protected function changeState(event:MouseEvent):void
                                    if(currentState=="fold")
                                              currentState="unfold";
                                    else
                                              currentState="fold";
      and i defined two properties,header and body here,but i don't instantiate here,and then i worte a mxml component "FoldUnit.mxml" that extends "Base" and i will instantiate header and body in it,code like this
          <local:Base xmlns:fx="http://ns.adobe.com/mxml/2009"
                                    xmlns:s="library://ns.adobe.com/flex/spark" currentState="fold" clipAndEnableScrolling="true"
                                    xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:local="*" width="200" >
                <local:states>
                          <s:State name="fold" />
                          <s:State name="unfold" />
                </local:states>
                <local:transitions>
                          <s:Transition toState="fold">
                                    <s:Sequence>
                                              <s:Resize target="{this}" duration="400" />
                                              <s:RemoveAction target="{body}" />
                                    </s:Sequence>
                          </s:Transition>
                          <s:Transition toState="unfold">
                          </s:Transition>
                </local:transitions>
                <s:Group id="header" width="100%">
                          <s:Rect height="40" width="100%">
                                    <s:fill>
                                              <s:SolidColor color="0xff0000" />
                                    </s:fill>
                          </s:Rect>
                </s:Group>
                <s:Group id="body" includeIn="unfold" y="40" width="100%">
                          <s:Rect height="200" width="100%">
                                    <s:fill>
                                              <s:SolidColor color="0x00ff00" />
                                    </s:fill>
                          </s:Rect>
                </s:Group>
          </local:Base>
      after all,i placed three of FoldUnit in main application to simulate an accordion component.
                                       xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:local="*">
                <s:Group>
                          <s:layout>
                                    <s:VerticalLayout variableRowHeight="true" />
                          </s:layout>
                          <local:FoldUnit />
                          <local:FoldUnit />
                          <local:FoldUnit />
                </s:Group>
          </s:Application>
      everything like fine,however,if i try to click one red header to fold up,that green body just disappear immediately,looks like that RemoveAction tag is useless.
      so,as i try to figure out why,i made things simple first,and i combine that function in Base.as into FoldUnit.mxml,then it works fine.
      so,i wonder is there a bug or something?
      PS:i don't wanna use a skinable component,coz' the size measure process always delayed,it's hard to location the scroll position in scroll bar.
