1. Re: Can I create a hotspot within a slideshow?
Sanjit_Das Jan 17, 2014 5:38 PM (in response to JerryPF)Hi Jerry
Not sure if I have understood properly , but if you are referring to "Next" and "Previous" buttons then you can modify them accordingly.
The page link that you have mentioned does also contains next and previous buttons , if you want the images for backward and forward in your slide show then you can use the image as Fill for next and previous boxes.
Alternatively , if you want to place a button (hotspot) on the image itself , then you can drag the next button over image , make it no fill , so that on click it would take to next image.
Sanjit
2. Re: Can I create a hotspot within a slideshow?
JerryPF Jan 18, 2014 12:15 AM (in response to Sanjit_Das)Thanks Sanjit
In this instance I wanted an extra, or second forward button, just on this particular slide of the slideshow. If I move the next button, and make it invisible, that will apply to the whole slideshow. I could duplicate the slideshow onto another page (screen), but how can I get the same fade transition I'm getting between slides? And might it lag due to load time?
Jerry
3. Re: Can I create a hotspot within a slideshow?
Sanjit_Das Jan 20, 2014 11:36 AM (in response to JerryPF)Hi Jerry
Slidehow on a page and duplicate on another page with Fade transition effect on pages would not be possible at current stage.
Sanjit
