2 Replies Latest reply on Jan 14, 2014 6:21 AM by JJLEDOUX
    Multiple choice fields
      I would like to be able to use the rating scale as a multiple choice feild, so I can check multiple selections.
        • 1. Re: Multiple choice fields
          Josh_Corey Adobe Employee
          If you are asking to be able to select more than one "rating" accross that is not supported (as I am sure you found), but I'd think you can achieve something functionally similar using rows of Multi-select fields and changing the formatting on them so that they have labels left or right, and uncheck the "Stack vertically" so that the choices are in a row, rows of fields could make rough columns (you could label the choices in just the top row/field or in all, same labels in all would align all of the rows choices).  I know it would not be as ideal as in a table, there would be unnecessary space and things might not line up as well, but with some manipulation it could work.
          • 2. Re: Multiple choice fields
            JJLEDOUX Level 1
            Thanks for your rapid response, I will try the options you suggested.
