17 Replies Latest reply: Nov 13, 2014 11:45 AM by choppper RSS
    Unable to sync due to server error
    Miemo Penttinen Community Member
      I keep on getting server error on a 25MB PSD file sync to Creative Cloud. The main Creative Cloud desktop app says "Unable to sync files" and when I click on "Learn more" I get a dialog saying "Unable to sync <file name> due to server error". Perhaps one in 20 syncs goes through OK, but most of the time it does not. This is frustrating to say the least, now I basically have to create JPG from the file and share it via Dropbox, rendering CC file sharing useless for me.
        • 1. Re: Unable to sync due to server error
          And yes, I've tried all the usual suspects: restarting computer, logging out & back in to CC, checking network connection, ...
          • 2. Re: Unable to sync due to server error
            Ken G. Rice Employee Hosts
            To help us figure out what happened we need the log files for desktop sync (CoreSync). The location for each OS are:
            • Mac OS X: ~/Library/Application Support/Adobe/CoreSync/CoreSync-yyyy-mm-dd.log
            • Windows: %APPDATA%/Adobe/CoreSync/CoreSync-yyyy-mm-dd.log
            Note that on Mac OS X to see the user library from the Finder click on the Go menu and hold down the Alt/Option key. Note that on Windows %APPDATA% is a variable that will change to the correct path depending on what version of Windows being used.
            Email the log files to kenrice@adobe.com.
            • 3. Re: Unable to sync due to server error
              DigitalFuel Community Member
              Hi Ken
              I have the same error. And I have sent you some log files.
              Some files sync but others do not. The sync error seems to happen when you open a file ie .indd to edit then when you save it down again you get the error. If I Archive the file in the web portal then it will cause the files to re-sync properly.
              Has been happening for the last week or so
              Cheers Daniel
              • 4. Re: Unable to sync due to server error
                Thanks for the email last week. We were able to resolve the issue.
                • 5. Re: Unable to sync due to server error
                  Thank you Ken for getting this fixed.
                  • 6. Re: Unable to sync due to server error
                    BlueZilla Community Member
                    Hi Ken,
                    I have the same problem with my CC. Possible to email you the CoreSync log files?
                    With kind regards,
                    • 7. Re: Unable to sync due to server error
                      greg_starkey Community Member
                      Hi Ken,
                      I have been getting this error on and off for at least the last 5 months. What issues have you resolved? CC Sync is still getting errors when my iMac and MBP are on and connected. Sometimes the sync works, sometimes it doesn't. Then there are the conflicted files-they happen a lot, too. I was hoping that with the latest update to the CC app, my files would sync without having the same issues over and over again.
                      Also, having Generate on in Photoshop causes many issues with the sync.
                      What is the key to making CC Sync work correctly?
                      Suggestion - when sync issues happen, the error icon on the file should stay on after the error happens, so the user could identify the problem files. It currently goes away when the error message comes up.
                      • 8. Re: Unable to sync due to server error
                        HI Greg it was the server error message that was fixed. This has not happened to me again.
                        I do agree with you though I use a pc and get the same issues. Lots of conflicts too many and the conflict are not because two instances overlapping either. they just happen the file conflict with themselves. I get errors for the inlk file but why as this is a temp file that indesign creates and surely the software can handle ignoring these temp files especially those created by adobe products as they are not uploaded anyway.
                        I love the Idea of sync and it is good but to be a real pro solution the bugs need fixing. and the storage limit needs increasing. I will pay for more storage but only if they fix the bugs. Lots of Conflicting files does not give inspire much confidence.
                        Good solution that could be great.
                        • 9. Re: Unable to sync due to server error
                          Digital Fuel Web Community Member
                          Hi Ken
                          I have been having the same unable to sync due to server error that I was getting a while ago for a while now. It happens to almost every file now and it had not done it for a bit. If I copy and paste a file it is ok. if I open a file and save it. I get server error. I just saved a pdf and it sync'd. I then re-saved it 10 min later to update it and it is getting the unable to sync due to server error.
                          This is a major pain and is making what could be a great thing into a waste of time. I receive the latest unpated this morning and it has not fixed the problem. In fact it has even more issues when you click on the button that says view on CreativeCloud.com it opens up the local folder and the display also has an issue with the error message and the view link overlapping and this is a new problem.
                          Please help. Else I will have to move the files back to onedrive which is not as good for adobe files but it does work.
                          • 10. Re: Unable to sync due to server error
                            jbellison Community Member
                            I am getting the exact same server error on many of the files I have in Creative Cloud Files.
                            I was excited to use this service but it has been a serious headache ever since I 'upgraded' to CC...
                            (P.S. Adobe: Dropbox never fails me.)
                            • 11. Re: Unable to sync due to server error
                              I was also excited about CC storage and I am having a little better time of it these days on a PC but it has been a headache to get here. There is still the odd glitch. I too have never seen an error on dropbox it does just work.
                              One other error that you can get is if you sync a file on one computer and then on another that has not synced because it has no connection at the time because each time CC storage updates it looses the login details. If you create a duplicate folder things get ugly CC storage sometimes creates an odd folder with files in it that do not merge or ask for a solution ie merge or rename and that cannot be delete even in the web portal also giving a sync error. It takes a lot of trouble to fix. Yes this is an odd scenario but it can happen. Has only happened once but it did my head in trying to fix it. Not sure how I did in the end eventually it let me delete the folder and all returned too normal.
                              • 12. Re: Unable to sync due to server error
                                teenagethunderbolt Community Member
                                Hello I'd like to chip in and say I am also having that same error. I just got a new MacBook Pro and just installed Creative Cloud on this machine for the first time. The error occurred for 25 files that have successfully synced on both Windows and Mac computers in the past (I've been through several computers here lately). Is there a fix?
                                • 13. Re: Unable to sync due to server error
                                  derekajack Employee Hosts
                                  Hi Teenagethunderbolt,
                                  Could you send a copy of the Coresync.log file, which you will find at:
                                  Mac - /Library/Application Support/Adobe/CoreSync/CoreSync-yyyy-mm-dd.log
                                  (On Mac, you need to use the Go To Folder option from the Go option in Finder (menu at the top).  Then in the pop up enter:
                                  /users/username/Library/Application Support/Adobe/CoreSync/Then select go, this will take you to the folder containing the .log files.)
                                  This may help us understand the issue you're experiencing.
                                  Please email this to me directly on djack@adobe.com
                                  • 14. Re: Unable to sync due to server error
                                    The problem has changed and now it says my files are synced, but there are no files in my Creative Cloud folder. This is the CoreSync file from today.
                                    • 15. Re: Unable to sync due to server error
                                      aorzol Community Member
                                      Hello, my boss is experiencing the same problem on her MacBook Pro. We have a Creative Cloud team membership, and share files through a shared folder in Creative Cloud. Files have not been syncing on her computer for a few weeks now. It keeps trying, but always fails. I work on an older PC and have had no syncing difficulties. We have the latest Creative Cloud and program updates. New files or updated pre-existing files, in multiple programs, have not been syncing. And like other people have described, it says "Unable to sync due to server error." We use the same internet network at work, and granted it is achingly slow at times, but it has not affected syncing functionality before, only its speed. Something new must be going on with her computer... Could Ken or another staff member help us with this? Thanks!
                                      • 16. Re: Unable to sync due to server error
                                        @aorzol - Per reply #2 above please send the CoreSync logs from your boss' machine. And go ahead and send the logs from your machine too. We will investigate.
                                        • 17. Re: Unable to sync due to server error
                                          choppper Community Member
                                          I just sent you a email Ken. My computer is doing the same annoying, inefficient "can not sync" error. Running on my Dell Inspiron 5721 with a I7, 8GB ram, Windows 7 Pro and a new SSD.
