4 Replies Latest reply on Jan 14, 2014 11:27 AM by zsuarez
    Formatting
    zsuarez
      How do I format the size of my cells?
        • 1. Re: Formatting
          Josh_Corey Adobe Employee
          Which field type are you trying to resize?  In general you can resize the right side of the text input box to make it narrower or wider.  You cannot change the height of boxes other than the Multi-line text field.  Let me know which field type and I can give more detail on what you can do with it.
          Josh
          • 2. Re: Formatting
            zsuarez Level 1
            We are having issues with the size of columns / rows in the form response table.  Not sure how we changed the width on several columns but is there any way to adjust without having to change one column at a time?
            • 3. Re: Formatting
              Ah - got it, great, thanks.
              You can resize a number of columns together (they'll resize to the same size) by selecting a group of columns (either shift+click or Crtl+click to select multiple) and then resizing one column by grabbing the vertical bar in between two column headers.  All of the selected columns will resize to the new size when you let go of the mouse.
              Josh
              • 4. Re: Formatting
                zsuarez Level 1
                Perfect!!! Thank you!!
