1 Reply Latest reply on Jan 15, 2014 9:09 AM by Josh_Corey
    I want to make a form fit on a single page by making the gaps around the fields smaller
    M4Mark
      The gaps around the questions is too large, how do I make them smaller
        • 1. Re: I want to make a form fit on a single page by making the gaps around the fields smaller
          Josh_Corey Adobe Employee
          In general the things that you can re-size per field are:
          • The width of the fields label (in a Label position Left or Right field)
          • The width of the text input box (and height for Multi-line text field)
          • The padding on the right side by resizing the right border of the field (the dotted outline)
          You cannot change the vertical distance between fields or reduce the distance between any more than resizing the right hand border (dotted outline) which does leave some padding between the fields.
          Josh
