This content has been marked as final.
Show 3 replies
1. Re: Sequence Settings Video Previews and GPU?
JSS1138 Jan 16, 2014 8:02 AM (in response to ArtifaktAstrix)The first two boxes only affect previews. The same boxes in the Export Settings dialog will override those and determine the output.
Using previews for export is generally not a good idea, as doing so will incur an additional compression step. The exception is when the previews are lossless (or nearly so, as with DNxHD).
Not working with ProRes, I've never seen those options.
2. Re: Sequence Settings Video Previews and GPU?
ArtifaktAstrix Jan 25, 2014 6:24 AM (in response to JSS1138)Thank you very much, that was helpful.
3. Re: Sequence Settings Video Previews and GPU?
JSS1138 Jan 25, 2014 9:21 AM (in response to ArtifaktAstrix)You're welcome.
