1 Reply Latest reply on Apr 16, 2009 11:44 AM by released87
    load and save xml
    zalmanoff
      I load data from xml file, but i can not save change on server. How save change in xml file on server?
        • 1. Re: load and save xml
          released87
          hi I usually load the XML and manipulate it with Actionscript. When I am done, I POST the updated XML to a PHP file which opens the file to be saved to and overwrite the contents.
          <mx:Script>
          <![CDATA[
          //Import
          import
          mx.controls.Alert;
          import
          flash.events.*;
          import
          flash.net.*;
          import
          mx.collections.XMLListCollection;
          import
          mx.rpc.http.*;
          import
          mx.rpc.events.*;
          import
          flash.net.FileReference;
          import
          mx.core.Application;
          //Objects
          private var requestXML:XML= new
          XML();
          private var loadRequest:HTTPService= new
          HTTPService();
          private var sendRequest:HTTPService= new
          HTTPService();
          private var variables:Object= new
          Object();
          private var uploadRequest:URLRequest= new
          URLRequest();
          private var uploadLoader:URLLoader= new
          URLLoader();
          private var uploadVars:URLVariables= new
          URLVariables();
          private var fileUpload:FileReference= new
          FileReference();
          //Bindable
          Bindable] public var
          imageString:String;
          topString:String;
          bottomString:String;
          outImage:String;;
          outTop:String;
          outBottom:String;
          global_Directory:String= Application.application.global_Directory;
          //Methods
          private function sendXML():void
          loadRequest.url= global_Directory+
          "XML/about.xml"
          loadRequest.method=
          "POST"
          loadRequest.resultFormat=
          'e4x'
          loadRequest.send(variables);
          loadRequest.addEventListener(ResultEvent.RESULT, loadXML);
          private function loadXML(event:ResultEvent):void
          requestXML= event.result
          as
          XML;
          display();
          private function display():void
          image_about.source= requestXML.image;
          input_image.text= requestXML.image;
          input_top.htmlText= requestXML.top;
          input_bottom.htmlText= requestXML.bottom;
          private function upload():void
          uploadRequest.url=
          "PHP/Actions.php"
          uploadRequest.method=
          "POST"
          uploadRequest.data= uploadVars;
          uploadVars.action=
          "image_upload"
          uploadVars.directory= global_Directory+
          "/Images/About/"
          fileUpload.upload(uploadRequest,
          "image"
          uploadLoader.load(uploadRequest);
          fileUpload.addEventListener(Event.COMPLETE, uploadCompleted);
          private function uploadCompleted(event:Event):void
          var image_url:String= global_Directory+"Images/About/"
          +event.target.name;
          input_image.text= image_url;
          image_about.source= image_url;
          private function edit():void
          requestXML= <about><image /><top /><bottom /></about>;
          requestXML.image= input_image.text;
          requestXML.top= input_top.htmlText;
          requestXML.bottom= input_bottom.htmlText;
          update();
          private function update():void
          sendRequest.url=
          "PHP/Actions.php"
          sendRequest.method=
          "POST"
          variables.action=
          "edit_about"
          variables.xmlString= requestXML;
          variables.directory= global_Directory;
          sendRequest.send(variables);
          sendRequest.addEventListener(ResultEvent.RESULT, updateComplete);
          sendRequest.addEventListener(FaultEvent.FAULT, updateFailed);
          private function updateComplete(event:ResultEvent):void
          Alert.show(
          "Update Complete"
          private function updateFailed(event:FaultEvent):void
          Alert.show(
          "Update failed."
          </mx:Script>
          <?php
          $action= $_POST['action'];
          $xmlString= $_POST['xmlString'];
          $directory= $_POST['directory'];
          $path = "../".$directory."XML/users.xml";
          $file = fopen($path, 'w');
          fwrite($file, $xmlString);
          fclose($file);
