3 Replies Latest reply on Jan 16, 2014 7:19 PM by heathrowe
    Multiple links within text
    AngieMM19 Level 1
      I am working on my first Animate project.  The project has several screens with short paragraphs of text on each screen.  Within several of the paragraphs, I need to set up multiple links rather than linking the entire text box to one URL.  Does anyone have a suggestion on how to do this?
      If it can't be done, I can set up transparent boxes with the links to sit on top of the text - not the best way to do this but it seems to work.  In that case, is there an easy way to "stop" the link just before the user moves to a different place in the timeline?
      Thank you!  I appreciate any suggestions!
        • 1. Re: Multiple links within text
          heathrowe Most Valuable Participant
          It can be done.
          Simple create an element with the Text Tool; put any thing in the text area (example i often just type 'placeholder').
          It will be oveerwritten later with the below code, using the html() method.
          Depending on how you trigger/ play / or show that text element, then do something like this.
          // Copy Below //////
          sym.$("Text1").html ("I am working on my first Animate project.  \
          The project has several screens with \
          short paragraphs of text on each screen. <a href = 'http://www.somewebsite.com/' target='_blank'>some link</a>  \
          The project has several screens with short paragraphs       \
          of text on each screen. \
          If it can't be done, I can set up transparent boxes with the links \
          to sit on top of the text - not the best way to \
          do this but it seems to work <a href = 'http://www.somewebsite.com/' target='_blank'>another link</a> ");
          // End Copy /////////
          Note the multiple link references above. The same as stndard html linking procedures.
          The trailing \ is to allow for carriage return within the code window and is for display only. They will not appear in the result.
          hth
          Darrell
          • 2. Re: Multiple links within text
            AngieMM19 Level 1
            Hi Darrell,
            Thank you so much!  It worked PERFECTLY!!  I really appreciate your help.
            Angie
            • 3. Re: Multiple links within text
              Super :-)
