5 Replies Latest reply on Apr 14, 2014 6:45 AM by eska66
    Memory decreases when we use PS CS6 on Mac
    eska66 Level 1
      Hello from France and Happy New Year,
      On 6 MacPro Early 2009:
      - RAM 16GB
      - ATI RADEON HD5870 +  NVidia GT120
      - Mac OS 10.8.5
      - HD 2 TB
      - CS6 last version
      - Suitcase 16.0.4
      We work everyday with differents softwares: PS, Illustrator, Word, Excel, PPT, Filemaker, Firefox.... Everything works fine, except when we start to work with PS -> memory is decreasing very quickly. I installed Memory Clean to see what happens. The memory is getting very low: 8 MB!!!
      We have this this problem everyday, all of the day, with samll files or big files, and we have to use Memory Clean each hour or to quit PS. If I don't use PS, no problem.
      I installed 32GB on a Mac, and the problem is the same.
      Any idea?
      Stéphane
        • 1. Re: Memory decreases when we use PS CS6 on Mac
          eska66 Level 1
          Hello,
          Any idea about my problem? It is really difficult to work, and to have no memory every 60 minutes.
          Stéphane
          • 2. Re: Memory decreases when we use PS CS6 on Mac
            PECourtejoie Adobe Community Professional
            Bonjour!
            Could you post the contents of help>system info...
            I know that the GT 120 does not work for some functions in CC, as it has bugs other cards don't.
            Do you use third party plug-ins?
            Merci!
            • 3. Re: Memory decreases when we use PS CS6 on Mac
              eska66 Level 1
              Bonjour, (and sorry about my English)
              Thanks. It is with CS6 not with CC.
              System Info following. PS says "Mémoire libre : 6981 Mo", but Activity Monitor and  Memory Clean said 3960 MB, decreasing..
              Any idea?
              Stéphane
              Version Adobe Photoshop : 13.0.6 (13.0.6 20131025.r.54 2013/10/25:21:00:00) x64
              Système d'exploitation : Mac OS 10.8.5
              Architecture système : UC Intel Famille :6, modèle :26, niveau :5 avec MMX, SSE Entier, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
              Nombre de processeurs physiques : 8
              Nombre de processeurs logiques : 16
              Vitesse du processeur : 2925 MHz
              Mémoire intégrée : 16384 Mo
              Mémoire disponible pour Photoshop : 14876 Mo
              Mémoire utilisée par Photoshop : 50 %
              Taille de la mosaïque d'images : 1024K
              Niveaux de mémoire cache de l'image : 4
              Dessin OpenGL : Activé.
              Mode de dessin OpenGL : Normal
              Mode OpenGL normal autorisé : Vrai.
              Mode OpenGL avancé autorisé : Vrai.
              Anciens GPU OpenGL autorisés : Non détectés.
              OpenCL Version : 2.1
              Version OpenGL : 2.1
              Taille de la texture rectangle vidéo : 8192
              Mémoire OpenGL : 1008 MB
              Fournisseur de la carte vidéo : NVIDIA Corporation
              Module de rendu de la carte vidéo : NVIDIA GeForce GT 120 OpenGL Engine
              Affichage : 3
              Profondeur d'affichage : 32
              Limites d'affichage : haut = 0, gauche = 1920, bas = 1080, droite = 3840
              ID du module de rendu vidéo : 16918028
              Mémoire vidéo : 512 Mo
              Affichage : 2
              Limites d'affichage : haut = 0, gauche = -1920, bas = 1200, droite = 0
              ID du module de rendu vidéo : 33695244
              Affichage : 1
              Affichage principal
              Limites d'affichage : haut = 0, gauche = 0, bas = 1200, droite = 1920
              ID du module de rendu vidéo : 16915201
              Mémoire vidéo : 1024 Mo
              Numéro de série : 90149624745939289415
              Dossier de l'application : /Applications/Adobe Photoshop CS6/
              Le disque de travail de Photoshop comporte l'E/S asynchrone activé.
              Volume(s) de travail :
              HD Poste 100, 1,79 T, 1,05 T libres
              Dossier des modules externes obligatoires : /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/
              Dossier principal des modules externes : /Applications/Adobe Photoshop CS6/Plug-ins/
              Dossier des modules externes complémentaires : non défini
              Composants installés :
                 adbeape.framework   adbeape   3.3.8.19346   66.1025012
                 AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
                 adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
                 AdobeACE.framework   AdobeACE   2.19.18.20743   66.507768
                 AdobeAGM.framework   AdobeAGM   4.26.20.20743   66.507768
                 AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
                 AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
                 AdobeBIB.framework   AdobeBIB   1.2.02.20743   66.507768
                 AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.507768
                 AdobeCoolType.framework   AdobeCoolType   5.10.33.20743   66.507768
                 AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120720
                 AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
                 AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
                 AdobeLinguistic.framework      17206
                 AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
                 AdobeOwl.framework   AdobeOwl   5.0.4   79.517869
                 AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
                 AdobePDFSettings.framework   AdobePDFSettings   1.4
                 AdobePIP.framework   AdobePIP   7.0.0.1686
                 AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
                 AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                 AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
                 AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
                 AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
                 ahclient.framework   ahclient   1.7.0.56
                 aif_core.framework   AdobeAIF   3.0.00   62.490293
                 aif_ocl.framework   AdobeAIF   3.0.00   62.490293
                 aif_ogl.framework   AdobeAIF   3.0.00   62.490293
                 AlignmentLib.framework   xcode   1.0.0.1
                 amtlib.framework   amtlib   6.0.0.75
                 boost_date_time.framework   boost_date_time   6.0.0.0
                 boost_signals.framework   boost_signals   6.0.0.0
                 boost_system.framework   boost_system   6.0.0.0
                 boost_threads.framework   boost_threads   6.0.0.0
                 Cg.framework   NVIDIA Cg
                 CIT.framework   CIT   2.1.0.20577   146758
                 data_flow.framework   AdobeAIF   3.0.00   62.490293
                 dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
                 dvacore.framework   dvacore   6.0.0.0
                 dvamarshal.framework   dvamarshal   6.0.0.0
                 dvamediatypes.framework   dvamediatypes   6.0.0.0
                 dvaplayer.framework   dvaplayer   6.0.0.0
                 dvatransport.framework   dvatransport   6.0.0.0
                 dvaunittesting.framework   dvaunittesting   6.0.0.0
                 dynamiclink.framework   dynamiclink   6.0.0.0
                 FileInfo.framework   FileInfo   66.145433   66.145433
                 filter_graph.framework   AdobeAIF   3.0.00   62.490293
                 hydra_filters.framework   AdobeAIF   3.0.00   62.490293
                 ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
                 ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
                 image_compiler.framework   AdobeAIF   3.0.00   62.490293
                 image_flow.framework   AdobeAIF   3.0.00   62.490293
                 image_runtime.framework   AdobeAIF   3.0.00   62.490293
                 LogSession.framework   LogSession   2.1.2.1681
                 mediacoreif.framework   mediacoreif   6.0.0.0
                 PlugPlug.framework   PlugPlug   3.0.0.383
                 UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
                 wrservices.framework
              Modules externes obligatoires :
                 3D Studio 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “U3D.plugin”
                 Aplatissement 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “statistics.plugin”
                 Aquarelle 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Asymétrie 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “statistics.plugin”
                 Aérographe 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Barbouillage 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Bas-relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Camera Raw 8.3 (141), Copyright © 2013 Adobe Systems Incorporated - du fichier “Camera Raw.plugin”
                 Camera Raw Filter 8.3 (141), Copyright © 2013 Adobe Systems Incorporated - du fichier “Camera Raw.plugin”
                 Carrelage 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Cineon 13.0.6 x001  ©2002-2013 Adobe Systems Incorporated - du fichier “Cineon.plugin”
                 Cisaillement 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Collada DAE 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “U3D.plugin”
                 CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Contour accentué 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Contour déchiré 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Contour encré 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Contour lumineux 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Contour postérisé 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Contraction 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Coordonnées polaires 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Correction de l'objectif 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - du fichier “Lens Correct.plugin”
                 Couleurs NTSC 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - du fichier “NTSC Colors.plugin”
                 Couteau à palette 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Craie/Fusain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Crayon Conté 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Crayon de couleur 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Cristallisation 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Croisillons 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Demi-teintes couleur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Diagonales 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “dicom.plugin”
                 Dispersion 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Découpage 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Désentrelacement 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Eazel Acquire 13.0.6 x001  ©1997-2013 Adobe Systems Incorporated - du fichier “EazelAcquire.plugin”
                 Ecart type 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “statistics.plugin”
                 Effet mosaïque 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Effet pointilliste 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Emballage plastique 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Enregistrer pour le Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - du fichier “Save for Web.plugin”
                 Entropie 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “statistics.plugin”
                 Eponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Etalement 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Extrusion 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Fibres 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Filtre Collection d'images 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - du fichier “ChannelPort.plugin”
                 Filtre Rogner et désincliner les photos 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Flash 3D 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “U3D.plugin”
                 Flou de l'objectif 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - du fichier “Lens Blur.plugin”
                 Flou optimisé 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Flou radial 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Fluidité 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - du fichier “Liquify.plugin”
                 Format IFF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Fresque 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Galerie de filtres 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Google Earth 4 KMZ 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “U3D.plugin”
                 Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Grain photo 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Grand-angle adaptatif 13.0, Copyright © 2012 Adobe Systems Incorporated - du fichier “Adaptive Wide Angle.plugin”
                 Halo 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “HDRMergeUI.plugin”
                 Insertion filigrane NO VERSION - du fichier “DigiSign.plugin”
                 JPEG 2000 13.0.6 x001  ©2001-2013 Adobe Systems Incorporated - du fichier “JPEG2000.plugin”
                 Lecture filigrane NO VERSION - du fichier “DigiRead.plugin”
                 Lueur diffuse 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Matlab Operation 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - du fichier “ChannelPort.plugin”
                 Maximum 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “statistics.plugin”
                 Mezzo-tinto 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Minimum 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “statistics.plugin”
                 Moteur 3D Photoshop 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “Photoshop3DEngine.plugin”
                 Moyenne 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - du fichier “Average.plugin”
                 Moyenne 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “statistics.plugin”
                 Multiprocesseur 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - du fichier “MultiProcessor Support.plugin”
                 Médiane 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “statistics.plugin”
                 Noir/Blanc 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Noyau de mesures 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - du fichier “MeasurementCore.plugin”
                 Nuages 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - du fichier “Clouds.plugin”
                 Nuages par différence 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - du fichier “Clouds.plugin”
                 Néon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Océan 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Onde 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Ondulation 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Papier gaufré 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Papier humide 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 PCX 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - du fichier “PCX.plugin”
                 Peinture à l'huile 13.0, Copyright © 2011 Adobe Systems Incorporated - du fichier “Oil Paint.plugin”
                 Photocopie 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Pinceau à sec 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Pixar 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - du fichier “Pixar.plugin”
                 Placage de texture 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Plume calligraphique 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Plâtre 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Point de fuite 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “VanishingPoint.plugin”
                 Pointillisme 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Portable Bit Map 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - du fichier “PBM.plugin”
                 Portée 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “statistics.plugin”
                 Radiance 13.0.6 x001  ©2003-2013 Adobe Systems Incorporated - du fichier “Radiance.plugin”
                 Rogner et désincliner les photos 13.0.6 x001  ©2003-2013 Adobe Systems Incorporated - du fichier “CropPhotosAuto.plugin”
                 Routines FastCore 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - du fichier “FastCore.plugin”
                 Routines MMXCore 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - du fichier “MMXCore.plugin”
                 Réticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Solarisation 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - du fichier “Solarize.plugin”
                 Sommation 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “statistics.plugin”
                 Soufflerie 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Sous-couche 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Sphérisation 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 STL 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “U3D.plugin”
                 Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Support de script 13.0, Copyright © 2013 Adobe Systems Incorporated - du fichier “ScriptingSupport.plugin”
                 Tampon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Tourbillon 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Tracés vers Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
                 Trame de demi-teintes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Variance 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “statistics.plugin”
                 Verre 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Vitrail 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - du fichier “Filter Gallery.plugin”
                 Wavefront|OBJ 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - du fichier “U3D.plugin”
                 Wireless Bitmap 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - du fichier “WBMP.plugin”
                 Zigzag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - du fichier “Standard Multiplugin.plugin”
              Dossier des modules externes tiers et facultatifs :
                 3DxPhotoshop CS5 (12.0) ©1993-2010 Adobe Systems Incorporated - du fichier “3DxPhotoshopCS6.plugin”
                 Extensis 16.0.4.11, Copyright © 2013 Celartem, Inc., doing business as Extensis. All rights reserved. - du fichier “ExtensisFontManagementPSCS6.plugin”
              Modules externes dont le chargement a échoué : AUCUN
              Flash :
                 Mini Bridge
                 Extensis
                 Adobe Exchange
              Modules TWAIN installés : AUCUN
              • 4. Re: Memory decreases when we use PS CS6 on Mac
                eska66 Level 1
                Hello,
                Any idea helping me?
                I accept any idea to find the problem.
                Thx
                Stéphane
                • 5. Re: Memory decreases when we use PS CS6 on Mac
                  eska66 Level 1
                  Hello,
                  I put 32 Go on my Mac, and it is the same problem: each time I'm working with PS CS6, memory decreases continusly, to finally takes all of memory.
                  Any idea?
                  Thx
                  Stéphane
