2 Replies Latest reply on Apr 16, 2015 2:23 AM by PLAPLA
    Error E_ADEPT_NO_TOKEN
    Ardenstone
      This error comes up when I try to open a .acsm file sent to me by the distributor...can anyone help?
        • 1. Re: Error E_ADEPT_NO_TOKEN
          sjpt Level 4
          I assume this is opening it on ADE (digital editions)?
          One possibility is that ADE has got your authorization confused.
          Stock answer to quite a few problems, but not sure if it will help here.
          Usually gives a different message in that case, but all a bit random.
          Sometimes ADE gets its registration/activation confused and in a semi-authorized state.
          Uninstalling and reinstalling does not help, and indeed installation can even trigger this state.
          Unfortunately, it often then gives misleading error messages about what is wrong.
          A common incorrect message informs you that the ID is already in use on another computer and cannot be reused.
          Another is  "E_AUTH_NOT_READY"
          This can often be resolved by completely removing any authorization using ctrl-shift-D to the Library screen on ADE (cmd-shift-D if on Mac).
          Restart ADE, and then reauthorize with your (old) Adobe ID.
          In extreme cases on the mac, the following extra step has helped some people.  Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash. If you are using 10.7, see Access hidden user library files | Mac OS 10.7 Lion. http://forums.adobe.com/thread/1265248?tstart=0
          • 2. Re: Error E_ADEPT_NO_TOKEN
            PLAPLA
            Try by using another browser! and let me know if it works.
