6 Replies Latest reply on Jan 20, 2014 4:18 AM by egikas
    How to place an asset from the library to all pages via JavaScript?
    egikas
      Hello, I'm newbie in scripting that's why I need a help from one who knows. I need a javascript to place an asset from the library to all pages of my document.
      I've tried to do it but all i have :
      var myLibPath = (File("C:/Library.indl"));
      var myLib = app.open(myLibPath);
      var libItem = app.libraries[0].assets[0].placeAsset(app.documents[0]);
      this places asset to the selected page only, may be someone can tell me how can it works for all pages.
      Thanks!
        • 1. Re: How to place an asset from the library to all pages via JavaScript?
          Mi_D Level 3
          HI egikas,
          try below code
          var myPages = myDoc.pages;
          var libraryFilePath=new File("C:\\Library.indl");
          app.open(File(libraryFilePath));
          myAsset = app.libraries[0].assets.item("test");// change name ase per ur requirement
          for (var pg =0; myPages.length>pg; pg++)
                      var myObj = myAsset.placeAsset(app.documents.item(0))[0]; //first place library in first page
                      myObj.move (myPages[pg]);
                      myObj.move ( [15, 15] );//change ur x.y coodinate as per ur requirement
          Mi_D
          • 2. Re: How to place an asset from the library to all pages via JavaScript?
            egikas Level 1
            Thank you, Mi_D. that's what I need! But there's one problem, my document has facing pages, so your script place asset only at right or left pages. And I want it to place on the both sides of facing pages.
            May be you have a good idea how to solve it in a simple way:) ? I'd be very appreciated.
            • 3. Re: How to place an asset from the library to all pages via JavaScript?
              Mi_D Level 3
              I post u two mathod
              in first check right hand page or left head page
              if (myPages[pg].side==PageSideOptions.RIGHT_HAND){//check right firstpage
                       if (pg ==0){//check right firstpage
                          myObj.move ( [12, 15] );//change ur x.y coodinate as per ur requirement
                      else{
                          myObj.move ( [222, 15] )
              if(myPages[pg].side==PageSideOptions.LEFT_HAND){
              2nd mathod change page preferences spread to page
              myDoc.viewPreferences.rulerOrigin=RulerOrigin.pageOrigin;
              myDoc.viewPreferences.horizontalMeasurementUnits=MeasurementUnits.MILLIMETERS ;
              myDoc.viewPreferences.verticalMeasurementUnits=MeasurementUnits.MILLIMETERS;
              myDoc.zeroPoint=[0,0];
              Mi_D
              • 4. Re: How to place an asset from the library to all pages via JavaScript?
                egikas Level 1
                Hi, Mi_D. That's rock. Thank you a lot! Works great. You have solved my problems:)
                • 5. Re: How to place an asset from the library to all pages via JavaScript?
                  Mi_D Level 3
                  if pervious my post help u click yes in bottom
                  Was this helpful? Yes   No
                  • 6. Re: How to place an asset from the library to all pages via JavaScript?
                    egikas Level 1
                    hmm I clicked "Yes" evry time u answer me, so i'll do it once again
