32 Replies Latest reply on Feb 16, 2014 7:08 AM by BKBK
    binary data in a form field gets changed
    DonPedroElBuenoI
      I'm about to migrate a Coldfusion9 application running on SunOS to Coldfusion10 on Suse Linux.
      The webpages work perfectly on the new installation.
      However there is also kind of a system interface where clients post forms to a CF page where one of the form fields (intentionally) contains binary data mixed with plain text.
      This worked perfectly on the old installation.
      The formfield is taken out of the request using
      <cfset requestContent="#form.fieldt#"/>
      On the new installation this works for the plain text part, but the binary data is somehow changed.
      Any idea how I can prevent Coldfusion from changing the binary data?
      Pedro
        • 1. Re: binary data in a form field gets changed
          BKBK Adobe Community Professional & MVP
          Can you please bear with me. What you say confuses me a bit. What do you mean by "This worked perfectly on the old installation"? What failed to work, and what did you expect?
          Also, you say, "one of the form fields (intentionally) contains binary data mixed with plain text". However, the variable you have defined, requestContent, is neither binary nor a combination of binary and string. It is just a string.
          • 2. Re: binary data in a form field gets changed
            DonPedroElBuenoI Level 1
            "This worked perfectly on the old installation": What I meant is, that the data in the form field (i.e. binary data mixed with plain text) was in the variable requestContent as it was sent by the client.
            "What failed to work": In Coldfusion10 on Suse Linux, the binary data is not anymore as it was sent by the client (altough the plain text part remains correct). Some bytes (of the binary data) are dropped and the others are changed.
            "What did you expect": As described for the old installation.
            Thanks for your help
            Pedro
            • 3. Re: binary data in a form field gets changed
              Umhum, I see. What might likely have changed between the 2 installations is the encoding. If so, then the following should help:
              <cfif isDefined("form.fieldt")>
                  <cfset setEncoding("form", "UTF-8")>
                  <cfset requestContent="#form.fieldt#">
              </cfif>
              Should you wish to read more on encoding, take a look at this article by the inimitable Joel Spolsky: The Absolute Minimum Every Software Developer Absolutely, Positively Must Know About Unicode and Character Sets (No Excuses!).
              • 4. Re: binary data in a form field gets changed
                Thanks for that, but unfortunately, it didn't make it work.
                With the <cfset setEncoding("form", "UTF-8")>, the result was exactly the same as before.
                Btw the encoding on the old and on the new installation is set to ISO-8859-1.
                This is set in the CF Administrator:
                Java File Encoding:    ISO8859_1
                Java Default Locale:   en_US
                JVM arguments:        -Dfile.encoding=ISO-8859-1
                If in the .cfm I put the following:
                <cffile action= "write" file="/tmp/somefile.txt" output= "#getEncoding("form")#">
                the contents of somefile.txt is "ISO-8859-1" (i.e. of course without the <cfset setEncoding("form", "UTF-8")>).
                Any other suggestions?
                Pedro
                • 5. Re: binary data in a form field gets changed
                  Could you show us the code for your form?
                  • 6. Re: binary data in a form field gets changed
                    What do you mean by show us your from? The data content?
                    Is there a way I can dump the contents of the form to a file (or anywhere else I can read it)?
                    Below is just an example from the documentation... (the "Userdata" is the part which may be binary)
                    POST /DataInterface HTTP/1.0
                    Content-Type: multipart/form-data; boundary=123
                    User-Agent: MyClient/1.0
                    Content-Length: 232
                    --123
                    Content-Disposition: form-data; name="field"; filename=""
                    Content-Type: text/plain
                    PBRequest/2.0
                    SHA1-MAC: 977db7bd36625bfb67d1a1bc67e306230ef332be
                    Timestamp: 20020415T130553+0200
                    Type: Command
                    "Userdata"
                    --123--
                    • 7. Re: binary data in a form field gets changed
                      Ah, I had assumed the form is on your site. Your answer suggests otherwise.
                      In any case, it seems there are at least 2 form fields coming in, a binary (file) and plain text. You could just treat the form post as an upload. If you know the MIME type of the binary, then you could capture it and store it as a file.
                      Here follows a simple example in which I upload a PDF file (a binary) and some text. Ignore the fact that it is in Windows. What you are interested in are the 2 cffile tags. In your case, fileField = "Userdata" and output="#form.field#"
                      <cfif isDefined("Form.FileContents") >
                         <cffile action = "upload"
                             strict="false"
                              fileField = "FileContents"
                              destination = "c:\temp\upload\uploadFile.pdf"
                              accept = "application/pdf, binary/octet-stream"
                              nameConflict = "MakeUnique">
                         <cffile action="write" file="c:\temp\upload\uploadTxt.txt" output="#form.txtContent#">
                      Done uploading
                      <cfelse>
                          <form method="post" action=<cfoutput>#cgi.script_name#</cfoutput>
                              name="uploadForm" enctype="multipart/form-data">
                              <input name="FileContents" type="file">
                               <input name="txtContent" type="text">
                              <br>
                              <input name="submit" type="submit" value="Upload File">
                          </form>
                      </cfif>
                      • 8. Re: binary data in a form field gets changed
                        Seems I was very unclear in post #6... Sorry about that.
                        What you see there is the data we receive, not what we send...
                        And it is not about the file upload.
                        Altough we do also accept file uploads, this is not the part which causes problems.
                        The problem is only when the binary data is in the post.
                        • 9. Re: binary data in a form field gets changed
                          I made one more observation which is interesting:
                          After examining the differences more closely in a hex-editor I installed for that, i noticed that the difference is that all null-bytes (Hex 00) are changed to (Hex 20).
                          There seem to be no other differences between what is sent from the client and what I get in requestContent.
                          • 10. Re: binary data in a form field gets changed
                            They say ISO-8859-1 is byte-preserving, but I wonder what will happen if, just for the sake of testing, you change the encoding to UTF-8.
                            • 11. Re: binary data in a form field gets changed
                              Thanks, but I tried that before.
                              And I tried both, by setting UTF-8 in the administrator as well as the way you suggest in your post #3 <cfset setEncoding("form", "UTF-8")> in the cfm.
                              It actually makes it even worse. Not only are the Hex 00 converted to Hex 20, but also after some other binary data an additional byte is inserted.
                              • 12. Re: binary data in a form field gets changed
                                Sorry to hear. I wonder whether the problem results from the change from SunOS to Suse Linux, rather than the change from ColdFusion 9 to ColdFusion 10. By the time we apply encoding, it may be too late.
                                The Linux machine might be converting Hex 00 automatically to Hex 20. Any way to configure the settings on Suse Linux?
                                • 13. Re: binary data in a form field gets changed
                                  Another suggestion. Could it also be that the form fields are coming in as before, but what you use to open or view them has changed? Again, that might be the application converting Hex 00 automatically to Hex 20. If so, it might be possible to configure it to prevent conversion.
                                  • 14. Re: binary data in a form field gets changed
                                    All we basically do is to write the contents of the form field to a file.
                                    I already tried FileWrite() with different encodings (i.e. ISO-8859-1, UTF-8 and several others, as well as no encoding at all (which should be the same as ISO-8859-1)).
                                    Of course theoretically the problem could have been in the way this file is read. That's why I installed a hex-editor to make sure this is not the case.
                                    • 15. Re: binary data in a form field gets changed
                                      I scrolled back up and was duly reminded. You've done a good job at excluding the cases.
                                      So, it's time for new ideas. There is always the possibility that this behaviour changed between ColdFusion 9 and 10. We could therefore look a bit more in this direction.
                                      You asked earlier if there is a way to save the form field's content. What about making Coldfusion to treat it as an upload.
                                      <cfif isDefined("Form.Userdata") >
                                             strict="false"
                                              destination = "\your-server-path\uploadFile.ext" <!---Ext is a place holder for file extension--->
                                              accept = "binary/octet-stream" <!--- Even better, use MIME type for the file extension--->
                                      </cfif>
                                      Second test. For the purposes of elimination I would temporarily install a test version of ColdFusion 10 on SunOS, and see whether the problem occurs there. If it does, then we have enough information to report a ColdFusion 10 bug.
                                      • 16. Re: binary data in a form field gets changed
                                        Umhum, I don't really understand what the purpose of that file upload is (which may just be due to the fact that I'm far away from being a CF-expert).
                                        Anyway, when I tried it, I got the error "CF: The form field did not contain a file." (of course I changed "Userdata" to the real fieldname in the form).
                                        Another interesting information: I changed the JkLogLevel in Apache from info to debug. This writes the complete data traffic between Apache and coldfusion in hexadecimal to the logfile. There I can see, that the messages are still correct (i.e. they still contain the null bytes).
                                        • 17. Re: binary data in a form field gets changed
                                          Interesting observation: CF apparently doesn't consider the content of my form field as being binary. When I try the function BinaryEncode() on the form field, I get the error "Parameter 1 of the BinaryEncode function must be a valid binary object."
                                          Is there a way I can tell CF that it is a binary object? I haven't found anything in the manual...
                                          And one more question:
                                          Is there a way I can access the complete post as it was sent by the client (i.e. starting from "POST /DataInterface HTTP/1.0" to the very end) without having CF parsing out the fields?
                                          Parsing out the relevant field by myself would be easy enough.
                                          • 18. Re: binary data in a form field gets changed
                                            Just an update...
                                            I thought I had found the solution to my last question by myself as I found the function GetHttpRequestData().
                                            I was wrong! When I tried the follwing
                                              <cfset x = GetHttpRequestData()>
                                              <cfif isBinary(x.content)>
                                                <cfscript>
                                                  FileWrite("/tmp/binarycontent", "#x.content#");
                                                  encContent = binaryEncode("#x.content#", "Hex");
                                                  FileWrite("/tmp/encbinarycontent", "#encContent#");
                                                </cfscript>
                                              <cfelse>
                                                <cffile action      = "write"
                                                        file        = "/tmp/nonbinarycontent"
                                                        output      = "#x.content#"
                                                        addNewLine  = "no"
                                              </cfif>
                                            the files /tmp/binarycontent and /tmp/encbinarycontent were written, but they were both empty.
                                            • 19. Re: binary data in a form field gets changed
                                              The upload was just a way of finding out whether the binary data is coming in as a file.
                                              Apache operates as middle-man between the client and ColdFusion. This therefore tells us it is likely to be ColdFusion that is converting Hex 00 to Hex 20.
                                              • 20. Re: binary data in a form field gets changed
                                                I think the one you want is binaryDecode. It converts binary data that has been encoded into a string back into binary data.
                                                Perhaps not, but there is certainly a way ColdFusion can tell you what it makes of the object:
                                                isBinary(varName)
                                                I can see you already knew this.
                                                I would say, quite simply
                                                <cfset fieldContent = form.userData>
                                                • 21. Re: binary data in a form field gets changed
                                                  I was wrong!
                                                  Indeed. GetHttpRequestData().content is a concatenation of all the form fields and their respective values, in the form
                                                  field1=value1&field2=value2&field3=value3&...
                                                      <cfscript>
                                                      </cfscript>
                                                    <cfelse>
                                                              addNewLine  = "no"
                                                    </cfif>
                                                  From what I have just said,  x.content is a string, not a binary. Therefore the else-block of this code will run.
                                                  • 22. Re: binary data in a form field gets changed
                                                    Thats not what I wanted... <cfset fieldContent = form.userData> ... this only gets me the content of the formfield userData, but what I'm trying to get here is the complete post as it was sent by the client (i.e. starting from "POST /DataInterface HTTP/1.0 Content-Type: multipart/form-data;" to the very last byte).
                                                    • 23. Re: binary data in a form field gets changed
                                                      Well actually the manual says the following about GetHttpRequestData().content:
                                                      Raw content from form submitted by client, in string or binary format. For content to be considered string data, the FORM request header "CONTENT_TYPE" must start with "text/" or be special case "application/x-www-form-urlencoded". Other types are stored as a binary object.
                                                      This does not seem to work, at least not in my case.
                                                      And by the way, the if block is executed in my code as you can see from the names of the files being written (unfortunately empty).
                                                      • 24. Re: binary data in a form field gets changed
                                                        You are right. I have had a look at the manual. With Content-Type = multipart/form-data, ColdFusion indeed promises to return a binary. Since it returns zero output in your case, this can only mean something has gone wrong.
                                                        I have decided to take a deeper look into this. Expect feedback from me soon.
                                                        • 25. Re: binary data in a form field gets changed
                                                          @BKBK:
                                                          Thanks a lot for your support.
                                                          This is an important project for us and even more so for our customer. The project is already delayed because of this issue. It sheds a bad light on us and Colfusion, so we want to get this fixed as soon as possible.
                                                          We really appreciate your help
                                                          • 26. Re: binary data in a form field gets changed
                                                            Don Pedro,
                                                            I have been busy testing the behaviour of getHttpRequestData(), when a form is submitted with method="post" and enctype="multipart/form-data". I am on ColdFusion 10.0.13.287689.
                                                            Now, I can fully understand your frustration. I am, unfortunately, about to dash your hopes even further.
                                                            You were correct in expecting getHttpRequestData() to return the complete post that the client sent. That is in fact what its function is. However, I have found that the scenario I describe in the first paragraph leads to a bug.
                                                            To reproduce the bug, run the following code:
                                                            <cfif isDefined("Form.fieldContent")>
        <cfoutput>
        isBinary(gethttpRequestData().content): #isBinary(gethttpRequestData().content)#<br>
        binaryEncode(gethttpRequestData().content, 'hex'): #binaryEncode(gethttpRequestData().content, 'hex')#<br>
        </cfoutput>
        <cfdump var="#gethttpRequestData().content#" label="gethttpRequestData().content dump">
        <cffile action="write" file="#expandPath('testBinary')#" output="#gethttpRequestData().content#">
                                                            </cfif>
                                                            <cfoutput><form method="post" action="#cgi.SCRIPT_NAME#" enctype="multipart/form-data"></cfoutput>
                                                            <input name="fieldContent" type="text">
                                                            <br>
                                                            <input name="sbmt" type="submit" value="Send">
                                                            </form>
                                                            Enter '0123456789' in the text field and submit the form. The result is as follows:
                                                            1) isBinary(gethttpRequestData().content) returns 'Yes'.
                                                            2) binaryEncode(gethttpRequestData().content, 'hex') returns an empty string.
                                                            3) The dump shows no detail, is therefore apparently blank.
                                                            4) The file, testBinary, is created, but has 0 bytes.
                                                            For a second opinion, I ran the same code on Railo 4.1.2.005. This version corresponds to ColdFusion 10. The Railo result was as follows:
                                                            1) isBinary(gethttpRequestData().content) returned 'true'.
                                                            2) binaryEncode(gethttpRequestData().content, 'hex') returned the string 2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D32303133303136383935373631330D0 A436F6E74656E742D446973706F736974696F6E3A20666F726D2D646174613B206E616D653D226669656C64436 F6E74656E74220D0A0D0A303132333435363738390D0A2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2 D2D2D2D2D2D2D32303133303136383935373631330D0A436F6E74656E742D446973706F736974696F6E3A20666 F726D2D646174613B206E616D653D2273626D74220D0A0D0A53656E640D0A2D2D2D2D2D2D2D2D2D2D2D2D2D2D2 D2D2D2D2D2D2D2D2D2D2D2D2D2D2D32303133303136383935373631332D2D0D0A
                                                            3) The dump returned a table entitled 'Native Array (byte[])', consisting of 2 rows. The contents of the rows were as follows:
                                                            First row
                                                            Column 1: Raw
                                                            Column 2: [45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,5 0,48,49,51,48,49,54,56,57,53,55,54,49,51,13,10,67,111,110,116,101,110,116,45,68,105,115,11 2,111,115,105,116,105,111,110,58,32,102,111,114,109,45,100,97,116,97,59,32,110,97,109,101, 61,34,102,105,101,108,100,67,111,110,116,101,110,116,34,13,10,13,10,48,49,50,51,52,53,54,5 5,56,57,13,10,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,4 5,45,45,45,50,48,49,51,48,49,54,56,57,53,55,54,49,51,13,10,67,111,110,116,101,110,116,45,6 8,105,115,112,111,115,105,116,105,111,110,58,32,102,111,114,109,45,100,97,116,97,59,32,110 ,97,109,101,61,34,115,98,109,116,34,13,10,13,10,83,101,110,100,13,10,45,45,45,45,45,45,45, 45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,45,50,48,49,51,48,49,54,56, 57,53,55,54,49,51,45,45,13,10]
                                                            Second row
                                                            Column 1: Base64 Encoded
                                                            Column 2: LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0yMDEzMDE2ODk1NzYxMw0KQ29udGVudC1EaXNwb3NpdGlvbjogZm 9ybS1kYXRhOyBuYW1lPSJmaWVsZENvbnRlbnQiDQoNCjAxMjM0NTY3ODkNCi0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tMjAxMzAxNjg5NTc2MTMNCkNvbnRlbnQtRGlzcG9zaXRpb246IGZvcm0tZGF0YTsgbmFtZT0ic2JtdCINCg 0KU2VuZA0KLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0yMDEzMDE2ODk1NzYxMy0tDQo=
                                                            4) The file, testBinary, is created. It has 257 bytes, and the following content:
                                                            -----------------------------20130168957613
                                                            Content-Disposition: form-data; name="fieldContent"
                                                            0123456789
                                                            Content-Disposition: form-data; name="sbmt"
                                                            Send
                                                            -----------------------------20130168957613--
                                                            • 28. Re: binary data in a form field gets changed
                                                              Please follow the bugbase link I've given and vote for the bug report. Let us hope it will get Adobe to pay more attention to the issue. In the meantime, I am looking for a work-around.
                                                              • 29. Re: binary data in a form field gets changed
        @ BKBK:
        Thanks a lot, we really appreciate your help.
        • 30. Re: binary data in a form field gets changed
        Just to let you know I have been busy looking for a suitable form-handler for multipart/form-data enctype. My research on this subject tells me there is something broken in the way ColdFusion handles form posts. There are more issues besides the getHttpRequestData bug we uncovered. For example, if you attempt to handle a 'posted' form using getPagecontext(), a null value is returned.
        I have tried the following methods, unsuccessfully:
        1) getHttpRequestData;
        2) getPageContext, for example
        req=getPagecontext().getRequest();
        res=getPagecontext().getResponse();
        /*Always returns null for forms submitted with method="post". Works as expected for forms submitted with method="get".*/
        data=req.getParameter("filecontent");
        out = res.getWriter();
        etc.
        3) implementing the doPost method in a FormHandler servlet that extends HttpServlet, and running the servlet via
        getPagecontext().forward("FormHandler");
        At the moment, I am grappling with the Apache FileUpload library.
        • 31. Re: binary data in a form field gets changed
        Thank you for your help.
        In order not to further upset our customers, we have decided to go live with Coldfusion9.
        But since we sooner or later have to change to Coldfusion10, we are still very much interested in the progress of this issue.
        Thank you again ...
        • 32. Re: binary data in a form field gets changed
        I have found a possible workaround. Follow these steps to use a servlet to implement a form-handler in ColdFusion 10, for a form whose method is 'post' and enctype 'multipart /form-data':
        1) Download the libraries to be used, namely, commons-fileupload-1.3.1.jar and commons-io-2.4.jar;
        2) Copy these 2 JAR files to your ColdFusion installation's /WEB-INF/lib/ directory;
        3) In the following code, replace C://temp// with an existing path on your file system, to indicate where form data is to be stored. Save the code as FormHandlerServlet.java. Compile the file, and save FormHandlerServlet.class into the directory /WEB-INF/lib/classes/;
        import java.io.*;
        import javax.servlet.*;
        import javax.servlet.http.*;
        import org.apache.commons.fileupload.*;
        import org.apache.commons.fileupload.servlet.*;
        import org.apache.commons.fileupload.util.Streams;
        //@WebServlet(name="FormHandlerServlet", urlPatterns={"/FormHandlerServlet"})
        public class FormHandlerServlet extends HttpServlet {
        protected void doPost(HttpServletRequest request,
        HttpServletResponse response) throws ServletException, IOException {
        response.setContentType("text/plain;charset=UTF-8");
        try {
        doUpload(request,response);
        catch(FileUploadException fue) {
        fue.printStackTrace();
        protected void doUpload (HttpServletRequest req, HttpServletResponse resp) throws FileUploadException, IOException {
        FileWriter outFile = new FileWriter("C://temp//formFieldData");
        PrintWriter writer = new PrintWriter(outFile);
        // Create a new file upload handler
        ServletFileUpload upload = new ServletFileUpload();
        // Parse the request
        FileItemIterator iter = upload.getItemIterator(req);
        while (iter.hasNext()) {
        FileItemStream item = iter.next();
        InputStream stream = item.openStream();
        if (item.isFormField()) {
        /* Case where form field is not 'file' type: write string to output */
        writer.print(Streams.asString(stream));
        writer.close();
        } else {
        /* Code to handle case where file is uploaded */
        4) Create a back-up of /WEB-INF/web.xml. This will enable you to revert to the original set-up.
        Open web.xml in a text editor. Add the following between the last </servlet> end-tag and the first <servlet-mapping> start-tag:
        <servlet>
        <display-name>FormHandlerServlet</display-name>
        <servlet-name>FormHandlerServlet</servlet-name>
        <servlet-class>FormHandlerServlet</servlet-class>
        </servlet>
        <servlet-mapping>
        <url-pattern>/FormHandlerServlet</url-pattern>
        </servlet-mapping>
        5) One consequence of these settings is that you should require your clients to post form data to the action-page "/FormHandlerServlet";
        6) Restart ColdFusion.
        7) When a client submits binary data as before, it will be saved as the file formFieldData.
