8 Replies Latest reply on Jan 18, 2014 12:07 PM by Indiiyana
    How can I keep my counter the same when a button is clicked?
    Indiiyana
      I have the following button code:
      import flash.events.MouseEvent;
      var btns:Array = new Array(this.R1, this.R2, this.R3, this.R4);
      var currentlySelected:String = "";
      txtCounter.text = '3';
      var counter = 3;
      function clickedFN(e:MouseEvent):void
                this.clearAllFN();
                e.target.gotoAndStop("on");
                subtractCount();
      function subtractCount()
                counter--;
                txtCounter.text = counter.toString();
      function clearAllFN():void
                for (var i:Number = 0; i < btns.length; i++)
                          btns[i].gotoAndStop("off");
                          btns[i].addEventListener(MouseEvent.CLICK, clickedFN);
      Basically, when the fourth button is selected I don't want anything to happen at all to the counter because the user had answered the question correctly.  How can I do this?  My code for the subtractCount to initalise is in the clickedFN function but I don't want that to happen to all of the buttons in my group as I only want that to happen to 3 of them.  I also tried the following IF statement within the function:
        this.clearAllFN();
        if (R1.selected || R2.selected || R3.selected == true)
             subtractCount();
        else if (R4.selected == true)
            // do nothing
      Alas, it didn't work.
      Thanks.
        • 1. Re: How can I keep my counter the same when a button is clicked?
          John Waller Adobe Community Professional & MVP
          Which Adobe software are you using?
          • 2. Re: How can I keep my counter the same when a button is clicked?
            Indiiyana Level 1
            Woops, sorry.  I am using Flash.
            • 3. Re: How can I keep my counter the same when a button is clicked?
              badfl
              var btns: Array = new Array(this.R1, this.R2, this.R3, this.R4);
              var currentlySelected: String = "";
              var counter = 3;
              function clickedFN(e: MouseEvent): void {
                        if(e.currentTarget==btns[3])
                                  return;
                        this.clearAllFN();
                        subtractCount();
              function subtractCount() {
                        counter--;
                        trace(counter);
              function clearAllFN(): void {
                        for (var i: Number = 0; i < btns.length; i++) {
              • 4. Re: How can I keep my counter the same when a button is clicked?
                Indiiyana Level 1
                Thanks man.
                I have another question.  Is there a way to initalise that counter variable globally so that it's kept consistent throughout the program?  I have that code in each of my questions in my quiz and when the user clicks "Next" to go to the next question it resets itself to 3.
                • 5. Re: How can I keep my counter the same when a button is clicked?
                  badfl Level 1
                  Click next question when counter is set to 3
                  Example:
                  nextBtn.addEventListener(MouseEvent.CLICK,nextClickHandler);
                  function nextClickHandler(event:MouseEvent):void
                            counter=3;
                  • 6. Re: How can I keep my counter the same when a button is clicked?
                    Indiiyana Level 1
                    Ah, I meant that when the next frame is shown, the counter is set itself back to 3, here's my code now for my radio group buttons:
                    import flash.media.Sound;
                    var myTimer:Timer = new Timer(5000, 1);
                    var snd:brba = new brba();
                    var counter = 3;
                              if(e.currentTarget==btns[0])
                                                            subtractCount();
                                          else if(e.currentTarget == btns[1])
                                                    subtractCount();
                                          else if(e.currentTarget == btns[2])
                                                    subtractCount();
                                          else if(e.currentTarget == btns[3])
                                                    var delay:Number = 4000; //delay before caling myDelayFunction
                                                    setTimeout(gotoNext, delay);
                                                    snd.play();
                                                    delete this.R1();
                                          this.clearAllFN();
                    function gotoNext()
                              MovieClip(root).gotoAndStop(4);
                              counter--;
                    Here's my second frame's radio group buttons' code:
                    var counter = 3;
                    var snd:miami = new miami();
                              if(e.currentTarget==btns[1])
                                                            subtractCount();
                                                    subtractCount();
                                                    subtractCount();
                                          else if(e.currentTarget == btns[0])
                                                    var delay:Number = 5000; //delay before caling myDelayFunction
                                                    snd.play();
                              this.clearAllFN();
                    function gotoNext()
                              MovieClip(root).gotoAndPlay(4);
                              counter--;
                    See what I mean?  I've removed the "Next" button now because when the user clicks the correct answer it goes to the next frame after a delay of whatever I set it as.  But I don't want it to reset itself to 3 all of the time, I just want it to be set once and that is applied to every frame in the entire program that has "Lives" in it.  So it's set as 3 once, then when it goes to the next frame it may be 2 or 1 if the user clicked the wrong answer and when the user does get the correct answer it goes to the next frame and it would be 2 or 1 if that was how it was previously.
                    • 7. Re: How can I keep my counter the same when a button is clicked?
                      badfl Level 1
                      Do not understand what you mean,
                      When the first frame var counter = 3;
                      The second frame when you can not define counter
                      Only direct assignment on it, because the declared variables are global.
                      For example:
                      First frame:
                      stop ();
                      var counter = 3;
                      counter = 5;
                      this.gotoAndStop (2);
                      When the second frame
                      trace (counter); / / 5
                      • 8. Re: How can I keep my counter the same when a button is clicked?
                        Indiiyana Level 1
                        Perhaps this will illustrate what I want better:
                        http://puu.sh/6pvLf.png
                        I tried doing the trace(counter) function but again the main problem is accessing the global variable in the first frame which is in a different timeline than the seperate radio group buttons.
