1. Re: Math.cos Math.sin = Math.HELP
Franck Payen Jan 18, 2014 7:56 PM (in response to W_J_T)Sounds "doable", although a picture of your expected result would be welcome, since i don't really understand the stepNum's increasing variable.
What i understand is you're trying to make polar moves from one element.
Does this picture reflect what you have in mind ?
Because it sounds more like a math issue than something impossible
2. Re: Math.cos Math.sin = Math.HELP
Franck Payen Jan 18, 2014 8:53 PM (in response to Franck Payen)By the way, it sounds more like a problem for Thales than sin cos (lengths divided by a parallel have equal ratios)
say :
Origin is the center of your selected object s0
dX0 and dY0 are the actual distance of this pathItem from the origin
var dx0 = (p.position[0] + p.width / 2) - (s0.position[0] + s0.width / 2);
var dy0 = (p.position[1] + p.height / 2) - (s0.position[1] + s0.height / 2);
dX1 and dY1 are the distance of this triangle from the origin
Knowing dx0/dx1 = dy0/dy1 = s0P0/s0P1
i suppose your StepNum determines the s0P0/s0P1 value…
(if i understood you well)
3. Re: Math.cos Math.sin = Math.HELP
CarlosCanto Jan 18, 2014 10:51 PM (in response to W_J_T)Hi W_J_T, here's one way to do what I think you want to do, I commented out the step increment so all items will "explode" the same distance, not sure if that's what you need.
first I'd move the calculation of the Selected object's center out of the loop, you only need to make the math once.
also,
(s0.position[0] + s0.width) / 2has a problem, it will not give you the center, check below// calculate Selection center position var cx = s0.position[0] + s0.width/2; var cy = s0.position[1] + s0.height/2;
then we're going to loop thru all items and calculate their center
// calculate pathItem's center position var px = p.position[0] + p.width/2; var py = p.position[1] + p.height/2;
we're going to skip calculating the distance from the selection's center to each item's center, we don't need it for this method, other methods could use this info.
now, your actual question about Sin/Cos
xn = Math.cos(Number(dx) * Math.PI / 180)+stepNum;sin(angle) and cos(angle) expect angles in Radians, you are not providing any angles in the formula above. We need to calculate the angle between Selection's center and each path's center
// get the angle formed between selection's center and current path's center var angle = get2pointAngle ([cx,cy], [px,py]);
once we have the angle we can apply it to our "Explosion" variable, I'm assuming is stepNum, and get its x and y distance it needs to move away from selection
// the distance to move is "stepNum" in the same direction as the angle found previously, get x and y vectors var dx = stepNum*Math.cos(angle);// distance x var dy = stepNum*Math.sin(angle);// distance y
all is left to do is move the paths, here's the whole thing
// Explosion, AKA move all items away from selection // carlos canto // http://forums.adobe.com/thread/1382853?tstart=0 var docID = app.activeDocument; var s0 = docID.selection[0]; pID = docID.pathItems; var stepNum = 20; // this is the distance to "explode" // calculate Selection center position var cx = s0.position[0] + s0.width/2; var cy = s0.position[1] + s0.height/2; for (var i = 0; i < pID.length; i++) { var p = pID[i]; // skip selected item if (!p.selected) { // calculate pathItem's center position var px = p.position[0] + p.width/2; var py = p.position[1] + p.height/2; // get the angle formed between selection's center and current path's center var angle = get2pointAngle ([cx,cy], [px,py]); // the distance to move is "stepNum" in the same direction as the angle found previously, get x and y vectors var dx = stepNum*Math.cos(angle);// distance x var dy = stepNum*Math.sin(angle);// distance y var moveMatrix = app.getTranslationMatrix(dx, dy); p.transform(moveMatrix); //stepNum+=stepNum; } } // return the angle from p1 to p2 in Radians. p1 is the origin, p2 rotates around p1 function get2pointAngle(p1, p2) { var angl = Math.atan2(p2[1] - p1[1], p2[0] - p1[0]); if (angl<0) { // atan2 returns angles from 0 to Pi, if angle is negative it means is over 180 deg or over Pi, add 360 deg or 2Pi, to get the absolute Positive angle from 0-360 deg angl = angl + 2*Math.PI; } return angl; } -
4. Re: Math.cos Math.sin = Math.HELP
pixxxel schubser Jan 19, 2014 10:09 AM (in response to CarlosCanto)@W_J_T,
at first I did not understand your question.
That made it a bit clearer for me (I hope so).
Perhaps this thread is the answer for you:
5. Re: Math.cos Math.sin = Math.HELP
W_J_T Jan 20, 2014 6:44 AM (in response to CarlosCanto)First off thanks so much to everyone for the valued input and feedback, thanks so much. Sorry for any confusion that my description and failed code attempt gave.
Thanks for your input Franck, I agree its certainly a math issue and more of a lack there of on my part for sure.
I think the concepts and thoughts you posted are indeed on the right track, thank you for the detailed thoughts and feedback.
Hi pixxxel schubser, thanks for the link, I have seen that in the past and was aware of it and noticed also that it had some similarities for this concept.
Greetings CarlosCanto, yes explode or disperse from a common center is what I was after. Thanks so much for your detailed code explanation and example, I think its on track to what I was after, thank you so much. It also appears a lot more involved than I had anticipated (ha ha) I really appreciate your knowledge as always. Regarding the step increment I was hoping to step the movement given the objects distance from the origin. I tried adding it back in such as: step += .2 // etc, with varied results. It seems like the code disperses things differently based on there distance, postion and already inherent rotation, some interesting results. I think you're pretty much spot on unless you have some additional thoughts or suggestion on properly implementing a step amount? Thanks Carlos.
Thanks again everyone for all the great input, thoughts, knowledge and assistance, wonderful stuff everyone thank you!
(I will certainly mark everything helpful and correct from all of you after any possible further feedback. Thanks again everyone, great stuff.
6. Re: Math.cos Math.sin = Math.HELP
CarlosCanto Jan 20, 2014 11:19 PM (in response to W_J_T)Regarding the step increment I was hoping to step the movement given the objects distance from the origin. I tried adding it back in such as: step += .2 // etc, with varied results. It seems like the code disperses things differently based on there distance
for that you need to create an "explodeRatio" variable that would decrement/increment the "explosion" distance. Close objects would "explode" more than far away objects
for example you can decide that objects in a 20 pts radius from the selection center would "explode" the full distance (20 pts), so your Ratio would need to equal 1.
// for close objects
var explode = 20;
var distance = 20; // distance from selection center to object center
var explodeRatio = explode/distance; // 20/20=1
var objectExplode = explode*explodeRatio; // 20*1=20, move 20 in its own direction
// for far objects
var explode = 20;
var distance = 100; // distance from selection center to object center
var explodeRatio = explode/distance; // 20/100=0.2
var objectExplode = explode*explodeRatio; // 20*0.2=4, move 4 in its own direction
7. Re: Math.cos Math.sin = Math.HELP
Thanks so much CarlosCanto for the additional information. So I assume past this new variable(s) that there is further math that needs to be in place with the bulk of the code to implement it and get this differentiation (near/far) and stepped approach? Sorry for my lack of full understanding of things, I appreciate your assistance and help.
8. Re: Math.cos Math.sin = Math.HELP
CarlosCanto Jan 21, 2014 11:30 AM (in response to W_J_T)I made the Math for you and created the variables too, you just need to incorporate that into my previous post
9. Re: Math.cos Math.sin = Math.HELP
W_J_T Jan 21, 2014 1:24 PM (in response to CarlosCanto)Sorry Carlos, I guess I am just not following and I am still confused as to how those variables get implemented into the previous code, am I just replacing stepNum with explodeRatio or objectExplode? Ugh.., I apologize for having such disconnect here properly understanding things, sorry to be such a burden at this point.
10. Re: Math.cos Math.sin = Math.HELP
CarlosCanto Jan 21, 2014 10:58 PM (in response to W_J_T)no problem, try this
// Explosion, AKA move all items away from selection // carlos canto // http://forums.adobe.com/thread/1382853?tstart=0 var docID = app.activeDocument; var s0 = docID.selection[0]; pID = docID.pathItems; var stepNum = 40; // this is the distance to "explode" // calculate Selection center position var cx = s0.position[0] + s0.width/2; var cy = s0.position[1] + s0.height/2; for (var i = 0; i < pID.length; i++) { var p = pID[i]; // skip selected item if (!p.selected) { // calculate pathItem's center position var px = p.position[0] + p.width/2; var py = p.position[1] + p.height/2; // get the angle formed between selection's center and current path's center & their distance var angle = get2pointAngle ([cx,cy], [px,py]); var distance = get2pointDistance ([cx,cy], [px,py]); var explodeRatio = stepNum/distance; // this can be built in any way you want, the longer the distance the lower the Ratio var objectExplode = stepNum*explodeRatio; // the distance to move is "stepNum" in the same direction as the angle found previously, get x and y vectors var dx = objectExplode*Math.cos(angle);// distance x var dy = objectExplode*Math.sin(angle);// distance y var moveMatrix = app.getTranslationMatrix(dx, dy); p.transform(moveMatrix); //stepNum+=stepNum; } } // return the angle from p1 to p2 in Radians. p1 is the origin, p2 rotates around p1 function get2pointAngle(p1, p2) { var angl = Math.atan2(p2[1] - p1[1], p2[0] - p1[0]); if (angl<0) { // atan2 returns angles from 0 to Pi, if angle is negative it means is over 180 deg or over Pi, add 360 deg or 2Pi, to get the absolute Positive angle from 0-360 deg angl = angl + 2*Math.PI; } return angl; } // return the distance from p1 to p2 function get2pointDistance(p1, p2) { return Math.sqrt ((Math.pow (p1[0]-p2[0], 2) + Math.pow (p1[1]-p2[1], 2))); } -
11. Re: Math.cos Math.sin = Math.HELP
W_J_T Jan 24, 2014 7:14 PM (in response to CarlosCanto)Thanks so much CarlosCanto for your continued involvement and knowledge sharing. Hey, you said there wasn't any more math but you added an entire function, ha ha just kidding. ;-)
Would you mind explaining that further: "built in any way"? For example, resulting then in various outcomes? For example Is it possible to reverse things so things far explode and things near don't? Or another example would be implode by contrast. Any input or feedback is welcome, but if your tired of it or me just say so. ;-) Thanks so much CarlosCanto, your awesome man.
EDIT: I went ahead and marked various posts correct and helpful. Carlos you must have got tired of my inquiries (ha, ha) thanks for your patience and willingness to assist. Thanks for all your help and to everyone whom was gracious enough to provide feedback, thanks so much everyone, its greatly appreciated. Thank you.
12. Re: Math.cos Math.sin = Math.HELP
CarlosCanto Jan 26, 2014 1:37 AM (in response to W_J_T)Would you mind explaining that further
the idea is to create a number that changes the actual amount to "explode" based on the distance.
to "implode", we just need to reverse the direction of the explosion by multiplying our ratio by -1...I used -5 for a more dramatic effect
change the script above to this values
var stepNum = 40; // 3
var explodeRatio = -5*stepNum/distance; // 3 implode
var objectExplode = stepNum*explodeRatio; // 3 implode
...just play with this values, change them around to your heart's content, get creative
var stepNum = 500; // 2
var explodeRatio = distance/stepNum; // 2
var objectExplode = stepNum*Math.pow (explodeRatio, 3); // 2
13. Re: Math.cos Math.sin = Math.HELP
W_J_T Jan 26, 2014 8:45 AM (in response to CarlosCanto)Thanks so much CarlosCanto for all your help and knowledge sharing as always. Now if only I had a script that could download your brain to my computer and txt editor.
