1. Re: Changes in line definition when converting from Freehand to jpeg format
maeric Jan 20, 2014 10:16 AM (in response to Blodwin)What happens if you export to other formats... same thing?
2. Re: Changes in line definition when converting from Freehand to jpeg format
Blodwin Jan 20, 2014 11:26 AM (in response to maeric)If I export it to pdf format all is OK.
I don't think I had any problem with HTML format. Unfortunately publishers want it in jpeg format in most cases.
3. Re: Changes in line definition when converting from Freehand to jpeg format
maeric Jan 20, 2014 11:53 AM (in response to Blodwin)I would try other raster-based formats like TIF and PNG to see if the problem is there. Also does this change happen to all dashed lines or only on a certain type of line? I would try various line widths, colors, straight/curve, group/ungroup, etc. to find if any variables cause this to happen or not.
Also, with the new Hard Drive did you reinstall the OS and Applications or was this a separate drive from your startup dirve? Did you have to reinstall FreeHand and remember to add all the updates? also set the preferences to your last version?
