1 Reply Latest reply on Jan 20, 2014 8:26 AM by tarossi
    ColdFusion Builder no longer finds my cfc file
    tarossi
      After a couple months of building a project with no real issues, all of a sudden my pages can no longer find my "ToolInvFunctions.cfc" file. I get this error,
      "The specified CFC ToolInvFunctions could not be found.
      The path to the CFC must be specified as a full path, or as a relative path from the current template, without the use of mappings."
      Like I said, everything has been working just fine until now and I have no idea what I may have done to start receiving this error. Here is the first
      line of code that fails with a call to the cfc file.
      <cfselect name="Tools"  bindonload="true" bind="cfc:ToolInvFunctions.findTools({ProcessIn})" display="RequestedTools" value="RequestedTools">
      </cfselect>
      All of this projects files reside in the same folder and have had no trouble finding each other until today.
      Please help, I imagine this is probably some sort of server issue, but I'm not experienced enough to diagnose.
      Thanks in advance
        • 1. Re: ColdFusion Builder no longer finds my cfc file
          tarossi Level 1
          Discovered the problem for those of you who may have the same issue. I was using nested if statements in a function to build my sql query and coldfusion apparently decided it no longer liked that. No idea why it causes the server to no longer find the cfc file, but once I changed how the if statements worked, it all started to function again.
