7 Replies Latest reply on Feb 1, 2014 4:15 PM by Colin Flashman
    Help
    creativejoan0425 Level 1
      I have a folder contain 2 indd files and one txt file
      I want to do a script if the folder contain a txt file then alert("a") one time;
      if folder not contain txt file do the other things alert("b") one time;
      Here is my script, but I found that if i have txt file, it will alert 5 times (bbabb)
      and if I didn't have txt file, it will alert 4 times (b)
      Test();
      function Test(){
      var DocFilePath = myDoc.filePath;
      var folder_Path = Folder(DocFilePath);
      var sourceChildrenArr = folder_Path.getFiles();
      for (var i = 0; i < sourceChildrenArr.length; i++) {
              var sourceChild = sourceChildrenArr[i];
          if (sourceChild instanceof File && sourceChild.name.match(/\.txt$/i)) {
              alert("a");
           else{
               alert("b");
        • 1. Re: Help
          Mi_D Level 3
          remove 1st two line like below
          Test();
          function Test(){
          var folder_Path = new Folder("E:\\Dummy\\test");
                  alert("a");
               else{
                   alert("b");
          in your code it's alert 5 time because it count two indd history file.
          And if u went in active Document tha in case of else you use else if like below
          Test();
          function Test(){
                  alert("a");
              else   if (sourceChild instanceof File && sourceChild.name.match(/\.indd$/i)){
                   alert("b");
          Mi_D
          • 2. Re: Help
            I try the second script, i use else if to instead of else
            but the result when my folder only have 2 indd files, it will alert("b") twice times, can fix it to be 1 time?
            if my folder contain 2 indd files and one txt file, it will alert 3 times (bba), can fix it to alert("a") 1 time?
            • 3. Re: Help
              and i try delete the else then it will show one time alert("a")
              Test();
              function Test(){
                      alert("a");
              • 4. Re: Help
                @creativejoan0425 – or use a counter in the if statement and evaluate the result of that counter after the for loop.
                Test();
                function Test(){
                var myCounter = 0;
                        // myCounter = myCounter + 1;
                        // short form:
                        ++myCounter;
                if(myCounter === 0){alert("b")};
                if(myCounter === 1){alert("a")};
                if(myCounter > 1){alert( "not a or b:"+"\t"+myCounter )};
                }; //END function Test()
                Uwe
                //EDIT: the snippet used ".log" suffix; changed that to ".txt".
                Message was edited by: Laubender
                • 5. Re: Help
                  Thx, it works
                  • 6. Re: Help
                    I want to ask what diffent between =, ==, ===?
