4 Replies Latest reply on Apr 28, 2014 7:16 AM by Jaswin
    InDesign CS6 Layout Adjustment issue
    Jaswin Level 1
      My Problem is with adjusting the Layout from a default template. Whenever I change the Trim size and Margin, the objects like textframe or image, and it is placed inside trim or at slug, will move accordingly with margin in previous versions. But this is not in the case CS6, this is totally unhelpful in changing layout quickly. Again this leads to adjust objects in Master frame. This is not much accurate on liquid layout as well. If I flow a text to next page after adjustments, the text box moves on the page flowed, and that is happening on all pages if i do that via script. Why the layout adjustment is not like previous versions in CS6?
      regards
      Jaswin
