CS5 Premiere Pro - Mac: Image of Text Degrades When Scale Up (Zoom In)
Video My Life Jan 19, 2014 1:07 PMGood day. I am given .pdf image files of text to use with my AVCHD video in creating projects to be exported to YouTube and DVD. My CS5 project will not import .pdf files so I have saved them as .tiff, .png, and .jpeg. In each case, the text within the image asset is very small and not legible when imported to fit the screen. So, I use the "Effect Controls" panel to scale up (zoom in) to various areas of the image in order to call out the most relevant text. The result is the text is extremely blurry and virtually unreadable; nothing I would ever publish. Here are the particulars:
Camcorder and native clips:
Sony HDR XR-550V
AVCHD format 1920 × 1080/60i
1,920 effective scanning lines and the interlace system.
The MPEG-4 AVC/H.264 format is adopted to compress video data.
MAC Pro:
Model Name: Mac Pro
Model Identifier: MacPro3,1
Processor Name: Quad Core Intel Xeon
Processor Speed: 2.8 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 12 MB
Memory: 10 GB
Bus Speed: 1.6 GHz
Memory:
Size: 1 GB (x2)
Type: DDR2 FB-DIMM
Speed: 800 MHz
Size: 4 GB (x2)
Type: DDR2 FB-DIMM
Speed: 800 MHz
Intel ES82 ACHI (x1, Main Drive)
Capacity: 239.71 GB Total, 92.43 GB Used
Model: OWC Mercury Electra 3G SSD
Intel ES82 ACHI (x1, Source Files Drive)
Capacity: 119.69 GB Total, 105.65 GB Used
Intel ES82 ACHI (x1, Cache and Project Export Drive):
Capacity: 119.69 GB Total, 89.31 GB Used
Graphics/Displays:
Chipset Model: NVIDIA GeForce GTX 285
Type: GPU
Bus: PCIe
VRAM (Total): 1024 MB
PCIe Lane Width: x16
Premiere CS5 Settings:
Project:
For editing AVCHD Formats recorded in anamorphic 1920x1080 (ex.1440x1080).
16:9 interlaced HD video at 29.97 frames per second.
48kHz audio.
Drop-Frame Timecode numbering.
Editing mode: AVCHD 1080i anamorphic
Timebase: 29.97fps
Video Settings
Frame size: 1440h 1080v (1.3333)
Frame rate: 29.97 frames/second
Pixel Aspect Ratio: HD Anamorphic 1080 (1.333)
Fields: Upper Field First
Audio Settings
Sample rate: 48000 samples/second
Sequence:
1440 x 1080
00;25;05;16, 29.97 fps
48000 Hz - Stereo
Imported Image Settings:
Type: JPEG
File Size: 8.6 MB
Image Size: 5100 x 6600
Pixel Depth: 24
Pixel Aspect Ratio: 1.0
Type: PNG
Resolution selected when converting from .pdf: 300
File Size: 421 KB
Image Size: 1275 x 1651
Pixel Depth: 24
Type: TIFF
File Size: 6.0 MB
Pixel Depth: 24
Compression: Huffman
Byte Ordering: Macintosh
Anything stick out in these specifications, folks? Thanks for your time!
