• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Flash player error
Guest
Jan 19, 2014 Jan 19, 2014
I'm using Flash on my Mac (OS X 10.9.1) and it's stopped working. I get the following error message:
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO             0000000000000000-0000000000001000 [    4K] ---/--- SM=NUL  /Volumes/VOLUME/Clinical Examination.app/Contents/MacOS/Flash Player
    __TEXT                 0000000000001000-00000000005f4000 [ 6092K] r-x/rwx SM=COW  /Volumes/VOLUME/Clinical Examination.app/Contents/MacOS/Flash Player
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libsystem_c.dylib                       0x947ac785 strlcpy + 53
1   com.apple.CoreServices.CarbonCore          0x92aa7901 UTF8ToFSSpecName + 50
2   com.apple.CoreServices.CarbonCore          0x92a4606d FSRefCreate + 423
3   com.apple.CoreServices.CarbonCore          0x92a46510 PBGetCatalogInfoSync + 1025
4   com.apple.CoreServices.CarbonCore          0x92a46107 FSGetCatalogInfo + 53
5   com.apple.CoreFoundation                0x99be8b5e filePathToHFSPath + 526
6   com.apple.CoreFoundation                0x99be7a27 URLPathToHFSPath + 151
7   com.apple.CoreFoundation                0x99abae3d CFURLCreateStringWithFileSystemPath + 477
8   com.apple.CoreFoundation                0x99ab750a CFURLCopyFileSystemPath + 426
9   com.macromedia.Flash Player.app          0x002ab2e0 0x1000 + 2794208
10  com.macromedia.Flash Player.app          0x002acd44 0x1000 + 2800964
11  com.macromedia.Flash Player.app          0x002c68b1 main + 2001
12  com.macromedia.Flash Player.app          0x00002892 0x1000 + 6290
13  com.macromedia.Flash Player.app          0x000027b9 0x1000 + 6073
Any advice?
Views
734
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Do a "clean install": How to perform a "clean install" of Flash Player in Mac OS X
What is ClinicalExamination app? Is that what you were using when it crashed?
It may require the standalone Player (Projector) Macintosh Flash Player 12 Projector
You'd need to copy that (standalone player) to the Contents/MacOS folder of the ClinicalExamination app by right clicking it and selecting "Show Package Contents"
Votes
Translate
Translate
Report
Report
Guest
Thanks Mike. I'd already done the 'clean install' twice... but still got that error message.
Yes, Clinical Examination is a DVD. It had worked previously using flash (this was the default option) but doesn't work now (i've upgraded to Mavericks in the meantime, but not sure if that's the problem).
I downloaded the flash projector as you suggested. I found the Content/MacOS folder as you suggested too (it contains a Flash Player 'Unix Executable File'). I tried to copy the new standalone player to this folder, but it wouldn't let me drop it in.
Any further ideas?
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
"I tried to copy the new standalone player to this folder, but it wouldn't let me drop it in."
Nope... You CAN'T copy it to the DVD. It's a "read only" medium.
What you'd need to do is copy the contents of the DVD to your HD and THEN replace the Projector with version 12.
You could then make a DMG of the contents and run the app from there.
More thsan likely, it's finding a version conflict between the Projector in the Contents/MacOS fodler and the newer one you've installed.
Does ClinicalExamination run in its own UI or does it use Safari?
Votes
Translate
Translate
Report
Report
