0 Replies Latest reply on Jan 19, 2014 6:55 PM by Sasano
    How to avoid MenuBar skipping some submenu hierarchy while opening menu?
    Sasano
      Hello here is my code and the result for different cases.
      I observed the same result for Flex3 and Flex4.
      It seems that when you have MenuItems nested as follows,
            - MenuItem a is in the MenuBar.
            - MenuItem b is in the submenu of a (let's call "submenu A").
            - No other MenuItem exists in submenu A.
            - MenuItem c is in the submenu of b (let's call "submenu B").
            - No other MenuItem exists in submenu B.
            - and so on..
      1 in every 2 menu don't appear. (In this case, submenu A,C,E,G,... don't show.)
      May anyone know the reason or how to fix it?
      Sample code:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                     initialize="init()" xmlns:local="*">
          <mx:Script>
              <![CDATA[
                  import mx.collections.XMLListCollection;
                  [Bindable]
                  public var menuBarCollection:XMLListCollection;
                  private var menubarXML:XMLList =
                      <menuitem label="Menu1" data="1">
                          <menuitem label="MenuItem 11" data="11"/>
                          <menuitem label="MenuItem 12" data="12">
                              <menuitem label="MenuItem 121" data="121">
                                  <menuitem label="MenuItem 1211" data="1211"/>
                              </menuitem>
                              <menuitem label="MenuItem 122" data="122">
                                  <menuitem label="MenuItem 1221" data="1221">
                                      <menuitem label="MenuItem 12211" data="12211"/>
                                  </menuitem>
                              </menuitem>
                              <menuitem label="MenuItem 123" data="123">
                                  <menuitem label="MenuItem 1231" data="1231">
                                      <menuitem label="MenuItem 12311" data="12311">
                                          <menuitem label="MenuItem 123111" data="123111"/>
                                      </menuitem>
                                  </menuitem>
                              </menuitem>
                              <menuitem label="MenuItem 124" data="124">
                                  <menuitem label="MenuItem 1241" data="1241">
                                      <menuitem label="MenuItem 12411" data="12411"/>
                                      <menuitem label="MenuItem 12412" data="12412"/>
                                  </menuitem>
                              </menuitem>
                          </menuitem>
                          <menuitem label="MenuItem 13" data="13"/>
                      </menuitem>
                      <menuitem label="Menu2" data="2">
                          <menuitem label="Menu2-1" data="2-1">
                              <menuitem label="Menu2-2" data="2-2">
                                  <menuitem label="Menu2-3" data="2-3">
                                      <menuitem label="Menu2-4" data="2-4">
                                          <menuitem label="Menu2-5" data="2-5">
                                              <menuitem label="Menu2-6" data="2-6">
                                                  <menuitem label="Menu2-7" data="2-7">
                                                      <menuitem label="Menu2-8" data="2-8">
                                                          <menuitem label="Menu2-9" data="2-9">
                                                              <menuitem label="Menu2-10" data="2-10">
                                                              </menuitem>
                                                          </menuitem>
                                                      </menuitem>
                                                  </menuitem>
                                              </menuitem>
                                          </menuitem>
                                      </menuitem>
                                   </menuitem>
                               </menuitem>
                           </menuitem>
                      </menuitem>
                  private function init():void {
                      menuBarCollection = new XMLListCollection(menubarXML);
          </mx:Script>
                <mx:MenuBar width="100%" dataProvider="{menuBarCollection}" labelField="@label"/>
      </mx:Application>
      Result: in this case, the following items don't appear.
      1221,1231,1241,2-2,2-4,2-6,2-8
