0 Replies Latest reply on Jan 20, 2014 12:29 AM by SourceSkyBoxer
    Problem with Loader using stage resizing
    SourceSkyBoxer Level 1
      Hello, sirs, and ladies,
      I want build 4 viewers ( as cam-viewer, top-, side. and front-viewer ) on one loader.
      I show you about my workstation;
      Is it ready? But i resize window and loader won't work because i have coded sometimes worng. If you know for fix slice 4 scaling.
      Look out! It went worng
      Here is my code:
      package
                import deng.fzip.FZip;
                import deng.fzip.FZipFile;
                import flash.display.Loader;
                import flash.display.Sprite;
                import flash.display.StageAlign;
                import flash.display.StageScaleMode;
                import flash.events.*;
                import flash.net.URLRequest;
                import flash.text.TextField;
                public class FZipTest extends Sprite
                          private var zip:FZip;
                          private var tf:TextField;
                          private var index:uint = 0;
                          private var count:uint = 0;
                          private var done:Boolean = false;
                          public function FZipTest() {
                                    // lets not scale
                                    stage.align = StageAlign.TOP_LEFT;
                                    stage.scaleMode = StageScaleMode.NO_SCALE;
                                    // status text
                                    tf = new TextField();
                                    tf.height = 20;
                                    tf.width = 576;
                                    addChild(tf);
                                    // load zip
                                    zip = new FZip();
                                    zip.addEventListener(Event.OPEN, onOpen);
                                    zip.addEventListener(Event.COMPLETE, onComplete);
                                    zip.load(new URLRequest("icons.zip"));
                          private function onOpen(evt:Event):void {
                                    addEventListener(Event.ENTER_FRAME, onEnterFrame);
                          private function onComplete(evt:Event):void {
                                    done = true;
                          private function onEnterFrame(evt:Event):void {
                                    // we only want to add 32 images at once to the display list
                                    // to save a bit of processor load when zip is cached
                                    for(var i:uint = 0; i < 32; i++) {
                                              // any new files available?
                                              if(zip.getFileCount() > index) {
                                                        // yeah, get it
                                                        var file:FZipFile = zip.getFileAt(index);
                                                        // is this a png in the icons folder?
                                                        if(file.filename.indexOf("icons/") == 0 && file.filename.indexOf(".swf") != -1) {
        // yeah, display it
        var loader:Loader = new Loader();
        loader.loadBytes(file.content);
        loader.x = (stage.stageWidth - loader.width) / 2 * (count % 2);
        loader.y = (stage.stageHeight - loader.height) / 2 * Math.floor(count / 2);
        loader.scaleX = stage.stageWidth + stage.width;
        loader.scaleY = stage.stageHeight + stage.height;
        addChild(loader);
        count++;
                                                        index++;
                                              } else {
                                                        // no new files available
                                                        // check if we're done
                                                        if(done) {
        removeEventListener(Event.ENTER_FRAME, onEnterFrame);
                                                        // and exit the loop
                                                        break;
                                    // display load status
                                    tf.text = count + " files loaded";
      I am using Flex SDK by Apache 4.11.0 SDK.
      There libraries i am using: fzip.swc and as3crypto.swc:
      And externed swfs are using mxml:
      app_1.swf = yellow
      app_2.swf = red
      app_3.swf = blue
      app_4.swf = green
      i have zipped 4 swf to icons/*.swf into icons.zip
      I have problem with slice 4-scaling for 4 loaded swfs and it will resize like any 3D drawing application for Away3D.like Autotesk Maya 4 Viewer or Blender 2.6x or 2.7x.
      Thanks for answer and suggestion.
      Best regards,
      Jens
