3 Replies Latest reply on Jan 22, 2014 8:35 AM by Josh_Corey
    Reaction as pdf instead of an an html overview
    Remco Jaspers
      I am using AdobeForms for receiving forms from different sales agents. Everytime they fill in a form, I receive an e-mail with an overview of what they have filled in. However, this is sort of a html summary of what they have filled in. I would like to receive the entire form as a pdf. The one you can export from the list of reactions when you are logged in at FormsCentral. Is that possible?
      Thanks in forward for your help.
        • 1. Re: Reaction as pdf instead of an an html overview
          Josh_Corey Adobe Employee
          Hi;
          That is a popular request but is not currently supported.
          Are you distributing your form as an HTML/web form or a PDF?  If you are using PDF you cuold add the Email action to the submit button, let me know if you'd like more information on setting this up.
          Josh
          • 2. Re: Reaction as pdf instead of an an html overview
            Remco Jaspers Level 1
            I would prefer to use it online (html/web form) and to receive forms that were filled in, as a pdf file.
            Another option would indeed be to use the form as a 'dynamic' pdf. If I understand correctly, AdobeForms offers the possibility to create a 'send by e-mail' button underneath a dynamic pdf then?
            I would be interested in more info on that.
            • 3. Re: Reaction as pdf instead of an an html overview
              FormsCentral PDFs are not dynamic.  What is your reference to Dynamic?  Are you thinking of forms created by Adobe LiveCycle (Dynamic XFA forms)?  FormsCentral creates "static" AcroForm type forms.
              You can use a PDF designed in and generated from FormsCentral in a more traditional work flow where you add a Submit button with the submit method of your choice to the PDF and don't use FormsCentral to collect the responses.
              One other options is to save your FormsCentral form as a Submission enabled PDF and then edit that PDF in Acrobat adding an additional Submit method to the existing Submit button that would open the default email client and attach the PDF to an email, it would also submit the data to FormsCentral, so if the user did complete sending the email you would recieve the PDF back as well as have the response data in your FormsCentral account.
              This FAQ describes how to edit a FormsCentral PDF in Acrobat: http://forums.adobe.com/docs/DOC-3661
              There are several tutorials online for adding the Emailo Submit method to a button, take care not to modify the existing actions on that button so you do not break the FormsCentral submit if you are trying to have both: http://www.youtube.com/watch?v=Jql1wp5Gofs
              Josh
