1 Reply Latest reply on Jan 20, 2014 1:18 PM by sjpt
    Computer Locks Up
    shocker2136
      used program a year or so then suddenly quit working.  I completely deleted it from computer then downloaded it again.  Clicking on program the screen opens but basically computer freezes and can't get to screen to authorize.  Help
        • 1. Re: Computer Locks Up
          sjpt Level 4
          Try installing ADE1.7.2 (see 2) ~~~) below and seeing if that will run.
          If it does, you will probably need to try 1) ~~~ below as well before you can get it to run properly.
          If even 1.7.2 fails, try
          • backing up the registry,
          • going into a registry editor,
          • deleting HKEY_CURRENT_USER\Software\Adobe\Adept\Activation and everything below it.
          1) ~~~~~
          Sometimes ADE gets its registration/activation confused and in a semi-authorized state.
          Uninstalling and reinstalling does not help, and indeed installation can even trigger this state.
          Unfortunately, it often then gives misleading error messages about what is wrong.
          A common incorrect message informs you that the ID is already in use on another computer and cannot be reused.
          Another is  "E_AUTH_NOT_READY"
          This can often be resolved by completely removing any authorization using ctrl-shift-D to the Library screen on ADE (cmd-shift-D if on Mac).
          Restart ADE, and then reauthorize with your (old) Adobe ID.
          In extreme cases on the mac, the following extra step has helped some people.  Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash. If you are using 10.7, see Access hidden user library files | Mac OS 10.7 Lion. http://forums.adobe.com/thread/1265248?tstart=0
          2) ~~~~~~~~~
          There are lots of bugs in ADE2.0 (and 2.0.1).  Try replacing ADE2.0 with the older but more reliable v1.7.2.
          (You can have them both installed at once if you like.)
          Version 1.7.2, it is a little difficult to find, available on Adobe site for Windows and for Mac.
          http://helpx.adobe.com/digital-editions/kb/cant-install-digital-editions.html
          The forum software is sometimes corrupting the link above.  There shouldn't be a blank in 'editio ns.html'.  The following redirects to the same page: http://tinyurl.com/diged172
          Some people have found ADE trying to upgrade automatically.
          It appears (not 100% sure) that if you install ADE2.0 as a new install (not as an upgrade) that your 1.7.2 will continue to run.
          Probably best to say no if 2.0.x installation asks if you want to migrate your library.
