I have a quiz question with multiple correct answers. Do I have to create an "Incorrect Answer" on all of the various combinations that are not correct. Or can I have one "Not Correct" that affects all of the wrong answers?
The multi-answer quiz question type only really allows you to have one failure caption, regardless of the combination of answers the user has selected.
Good morning Ron, I am not sure how to change or where to change the failure piece. Can you show me an example or call me at ???-???-????. Thank you Lisa
Message was edited by: Captiv8r - Removed sensitive information.
Please, don't post your credentials like phone number on a public forum.
Do you want to change the Failure Caption just for this question slide? Double-click on it or use F2 and you will able to edit the text.
Could you please mention the version of Captivate you are using, Lisa? Some features are different depending on the version.
http://blog.lilybiri.com/question-question-slides-in-captivate in this article I tried to describe the functionality of default question slides.
Lilybiri
Hi Thanks. I was not aware I was on a public forum until it was too late. I am very new to all of this. I am using version 7, and I think I have figured it out. Thank you Lisa
Lisa, can you check the exact version number of Captivate (Help, About...)? If you are still on 7.0.0.118, please install the free patch to 7.0.1.237.
Good morning Ron again, I would like to rephrase my question. Why can it only have 1 failure. And if they do not answer the question correctly, they are stuck at that screen. Please advise.
